ALL SBRS not enabled in Outgoing
Sep 23rd, 2008
in my log i see this message for outgoing:
REJECT SG None match ALL SBRS not enabled
i think that the mail is reject because the domain is not insert in to relylist of the sender group of the listener out.
Can you confirm?
p.s.
the global messagge is:
Tue Sep 23 13:20:12 2008 Info: New SMTP ICID 141940803 interface ascout (62.77.38.45) address 79.5.15.93 reverse dns host host93-15-static.5-79-b.business.telecomitalia.it verified yes
Tue Sep 23 13:20:12 2008 Info: ICID 141940803 REJECT SG None match ALL SBRS not enabled
Tue Sep 23 13:20:12 2008 Info: ICID 141940803 close
thank all for your help.
kluu_ironport Wed, 09/24/2008 - 02:17
You are correct that the connection from 79.5.15.93 (host93-15-static.5-79-b.business.telecomitalia.it) was rejected because the IP or the hostname was not on the RELAYLIST of that listener that it connected to.
In the example you provided, the listener is "ascout (62.77.38.45)". should have a relaylist at the top of the listener. You can add either the IP, IP range, hostname or partial hostname.
For example:
79.5.15.*
79.5.15.93-95
79.5.15.93
All the above will work.
Can you confirm?
p.s.
