Power Controller reports power Imax error detected
Sep 23rd, 2008
My 3560 switch w/ IOS 12.2(35)SE have below message last night. Would anyone know what happen?
Sep 23 18:54:58.468 UTC: %ILPOWER-7-DETECT: Interface Fa0/10: Power Device dete
ted: IEEE PD
Sep 23 18:54:58.468 UTC: %ILPOWER-5-INVALID_IEEE_CLASS: Interface Fa0/10: has d
tected invalid IEEE class: 7 device. Power denied
Sep 23 18:57:37.542 UTC: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error,
Interface Fa0/12: Power Controller reports power Imax error detected
Sep 23 18:57:44.580 UTC: %SWITCH_QOS_TB-5-TRUST_DEVICE_LOST: cisco-phone no lon
er detected on port Fa0/12, port set to untrusted.
Sep 23 18:57:48.674 UTC: %ILPOWER-7-DETECT: Interface Fa0/12: Power Device deteted: Cisco PD
Sep 23 18:57:48.741 UTC: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Fa0/12: Power Controller reports power Tstart error detected
Thanks and Regards
Ernest
Overall Rating: 5 (1 ratings)
Prashanth Krishnappa Tue, 09/23/2008 - 19:27
I am suspecting this has to do something with the IP phone on this port since it is requesting invalid class power. Did the phone come back up fine? If not, you might want to see if the same phone works on a different port or a switch to see if you just have a bad phone
We have a 2960 at one of our sites and we got notifications that all phones became unregistered.  I looked at the logs and saw
Sep 21 22:25:12.970 GMT: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Fa0/8: Power Controller reports power Imax error detected
Sep 21 22:25:13.675 GMT: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Fa0/15: Power Controller reports power Imax error detected
this appears to be affecting all our ports on that switch
Arumugam Muthaiah Sat, 09/22/2012 - 00:10
This error indicates that PD is drawing over-current more than allowed/supported per IEEE 802.3af standard.
Log:
  • What type of the device are connected to interfaces where you are seeing this error?
  • Do you use any kind of POE splitter on the interface?
This issue is looks like it is matching with known bug CSCsw18530
CSCsw18530 - Power Imax / Tstart errors may be reported with some third party PDs
Symptoms:
%ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Power Controller reports power Imax error detected
%ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/35: Power Controller reports power Tstart error detected
Conditions:
Seen with some of the 3750,3750G,3750-E,3560-E, 3750-X, 3560-X, 3560-C, 2960S, 2960,2960C switches
Workaround:
Longer cable (>50ft) seems to fix the issue in most cases.
Solution
This issue is fixed in 12.2(55)SE3 , 12.2(58)SE1 and later releases. The following  interface configuration commands have to be applied to resolve the issue,
Switch(config)# int x/y
Switch(config-if)# power inline port 2x-mode
Switch(config-if)# shut
Switch(config-if)# no shut
The fix is present in the following platforms only :
3750-E, 3560-E, 3750-X, 3560-X, 3560-C, 2960S, 2960,2960C. The other platforms do not support 2X power mode and the workaround would be to use a longer cable.
Aru
*** Please rate if the post is useful ***
Both ports had 7942 phones connected.  The switch is using IOS 12.2(58)SE2.  The ports are all in an up/up state now.  If the issue reoccurs I will try your suggestions.  On the same switch we do have two Meraki MR16 PoE WAP's connected also.  Is it possible they could be drawing too much power?  We'll keep monitoring.
Arumugam Muthaiah Tue, 09/25/2012 - 03:36
Hi Danny,
Please make sure that those two Meraki MR16 PoE WAP's are complaint to to 8023af standard. If this meets this standard, it will work without any trouble,
If you see any abnormal behavior on PoW, use the show inline power and show inline power detail privileged EXEC commands to compare the number of connected powered devices against the switch power budget (available PoE). Verify that switch power budget can power the device.
Note:
If the switch power budget is depleted, additional powered devices will not power-on when connected to a PoE port. CDP (Cisco Discovery Protocol) helps identify Cisco devices and correctly establish the switch power budget.
Refer:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/troubleshooting/g_power_over_ethernet.html#wp1018190
Aru
Mohamed Lotfy Mon, 02/22/2016 - 06:54
This issue is solved in 12.2(55)SE3 for 3560-X and working well.
and i upgraded IOS c3560-ipbasek9-mz.122-55.SE3.bin but the command #power inline port 2x-mode not available in IOS.
Look forward for someone response to resolve this issue
Thank you all.
Mohamed Lotfy Tue, 03/01/2016 - 02:53
after upgraded to 12.(55)SE10 still the command #power inline port 2x-mode not available.
waiting your replay
smogra Mon, 03/04/2013 - 06:26
Yes, looks like you are hitting this bug (CSCsw18530) and why this IMAX power error popup on Cisco switch:
After a PD (connected to one of our ports) is turned on, the hardware keeps on monitoring the current drawn by the PD so if the current drawn by a PD exceeds the pre-configured cutoff current (ICUT) for a limited time (TCUT) then the power controller will shut it down and informs the software about the fault. The software upon hearing about this fault, will print out the "IMAX error" message, remove the power and start a timer to start detecting the PD after the expiry of that timer. So if the device is continuously misbehaving (i.e. drawing more than ICUT current even after TCUT time) then we will keep on powering it up and then shutting it down.
Please try to connect longer cable (<50) and let me know if it's fix this issue or not.
Sweta
danielgold Wed, 06/25/2014 - 11:40
I just wanted to note that I was having the same issue with the "power Imax error" and I initially attempted the config for power inline port 2x-mode:
Initially this did not work for my by simply issuing a shut, no shut comand.  However once I configured the interfaces with the "power inline 2x-mode", and then reloaded the entire switch/stack, all PDs powered up correctly and I had no errors.
It's worth a shot to attempt a full reload rather than shutting off the interface and bringing it back up.
boucherandre Tue, 02/26/2013 - 18:47
We are at the begining of a wireless deployment in an hospital here, and at this  time I have 2 Aruba AP105 that stop working this week with this error log:
%ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/19: Power Controller reports power Imax error detected
I try the workaround and the solution with the  "power inline port 2x-mode" command on a  2960s POE+ 12.2 55(se5), but still the same problem.  I also upgrade the firmware of the wireless controllers to the latest.
Someone can help?
thanks!
Leo Laohoo Tue, 02/26/2013 - 19:12
Try this ...
1.  Command:  test cable tdr int G1/0/19;
2.  Wait for 5 to 7 seconds;
3.  Command:  sh cable tdr int G1/0/19; and
4.  Post the output to #3.
boucherandre Wed, 02/27/2013 - 15:10
Here is the output:
TDR test last run on: February 27 23:06:23
Interface Speed Local pair Pair length        Remote pair Pair status
Gi1/0/19  auto  Pair A     91   +/- 0  meters N/A         Normal
                Pair B     87   +/- 0  meters N/A         Normal
                Pair C     90   +/- 0  meters N/A         Normal
                Pair D     88   +/- 0  meters N/A         Normal
Leo Laohoo Wed, 02/27/2013 - 15:31
Entire length of the cable looks good.
What's the IOS of your switch?
boucherandre Wed, 02/27/2013 - 17:00
IOS of my switch is:
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 12.2(55)SE5, RELEASE SOFTWARE (fc1)
Here is some tests I had just done:
I replace 1 fail AP with a new one and it work just fine (like 40 others without the
"power inline port 2x-mode")
I test the fail AP in a HP POE switch and it work instantly...let it completly boot and connect with the controller
I put it back in my 2960 and fail again, I add the "power inline port 2x-mode" and this time it worked
I delete the 2x-mode and I'm back to the "power Imax error detected",put the 2x-mode again and it stop spamming me the error
Now, I'm absolutly sure I don't understand what's this mean...Is these 2 AP will fail again?  Do I need to add the 2x-mode on every AP of this kind? Is the 2x-mode overheat the AP or its just my mind that tricks me when I touched the device?
I'm done with tests tonight, just monitoring the AP and see if something strange happens.
thanks!
Leo Laohoo Wed, 02/27/2013 - 17:09
I've got 2960S and 3750X and I must humbly admint, I've never used this command line before.
Did you connect the AP directly to the switch port?
Hmmmm ... May I see the config of the offending port?  I've got a strange feeling that you have a command line that shouldn't be there.
boucherandre Wed, 02/27/2013 - 17:51
yes I got the same problem when connecting the AP directly in the switch port and any port.
Here is the port config (same on all port, except the 2x-mode that others identicals AP dont need :S)
description AP-ARUBA
switchport access vlan 204
switchport mode access
switchport priority extend trust
srr-queue bandwidth share 5 15 30 50
srr-queue bandwidth shape 0 0 0 0
priority-queue out
spanning-tree portfast
spanning-tree bpduguard enable
service-policy input reclass-cos
thanks
Leo Laohoo Wed, 02/27/2013 - 18:04
Odd.
Try this:
conf t
default interface
interface
spanning-tree portf
Try the interface commands above and let me know.
boucherandre Mon, 03/04/2013 - 05:41
OK, now these 2 AP are working with or without the 2x-mode.  They are probably failed and unstable and the HP switch are less sensible to their hardware failure then the csico switch? Anyway, I will open a case at Aruba for a RMA on those AP.
thanks guys!
Leo Laohoo Mon, 03/04/2013 - 14:04
Andre,
I reviewed your TDR output and I believe you have a cable issue 90 metres along the cable run.
Yes, the "status" shows NORMAL but look at the "Remote Pair" readings.  They are "N/A".
Vinod Hira Sun, 05/25/2014 - 15:52
Hello Guys
I have a same problem which is as follows:
We have about 2000 Nortel 1120E IP phone in production and as per Avaya PN that due to the designed fault in power module of the IP phone, the power module will fail after three years, which is start happening now. We have found the solution to repair the power module of the phone but when any IP phone fails due to the power module, our Cisco 3750 keep generating SYSLOG ( %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi4/0/9: Power Controller reports power Imax error detected) rather than ERRDISABLE the port.
So, is there way that as soon as switch detected this error then it can errdiable the port ? I have checked on switch about ERRDIABLE configuration which is as follows:
ErrDisable Reason            Detection    Mode
inline-power                 Enabled      port
pppoe-ia-rate-limit          Enabled      port
Below are the info about our Cisco Switches:
Model No: WS-C3750G-24PS-E
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(55)SE5,
I hope some one will have solution.
Thank you all.
Vinod
Leo Laohoo Sun, 05/25/2014 - 21:42
Try this ...
1.  Command:  test cable tdr int G4/0/9;
3.  Command:  sh cable tdr int G4/0/9; and
Vinod Hira Mon, 05/26/2014 - 15:41
Hi Leo
Thank you for your quick response but as I said before that Nortel IP phnoe has a designed fault in power module so it meant to fail and cisco switch generate syslog for this Power Controller reports power Imax error detected. Once we replace with new phone, the error disappear and works all fine.
Now the solution I am looking for this issue as follows:
While the faulty IP phone still pluged in and keep booting, the switch generate error log and our syslog server keep sending out email alert until one of our engineer log into switch and shut the port. Very often if this happen in weekend or at night then we get hundreds of email.
Therfore I think it would be nice if Cisco 3750 put this swithport into errdisable state but it's not happening.
This is the output of errdisable;
#sh errdisable detect
arp-inspection               Enabled      port
bpduguard                    Enabled      port
channel-misconfig (STP)      Enabled      port
community-limit              Enabled      port
dhcp-rate-limit              Enabled      port
dtp-flap                     Enabled      port
gbic-invalid                 Enabled      port
invalid-policy               Enabled      port
l2ptguard                    Enabled      port
link-flap                    Enabled      port
loopback                     Enabled      port
lsgroup                      Enabled      port
mac-limit                    Enabled      port
pagp-flap                    Enabled      port
port-mode-failure            Enabled      port
psecure-violation            Enabled      port/vlan
security-violation           Enabled      port
sfp-config-mismatch          Enabled      port
small-frame                  Enabled      port
storm-control                Enabled      port
udld                         Enabled      port
vmps                         Enabled      port
Another thing that this command "power inline port 2x-mode" is not available in our IOS, I am not sure how this command will help.
Look forward for someone response.
Thank you all.
Leo Laohoo Mon, 05/26/2014 - 17:44
Vinod,
Just want to make sure you've got 3750/G/E/X switch.  Because the answer to your question is an EEM script.
I would strongly recommend you create a new thread and post the new thread in the EEM Script section.  In the new thread, give as much details as you can, what you want the switch to do and someone, maybe Joe, will knock up an EEM script to automate stuff for you.
PS:  Post the link to the new thread here so people will know where to go.
Related Content
