R2 to SS7
Sep 23rd, 2008
Please, We need to migrate from r2 to ss7, can help me with some configuration in the AS54xx, the PGW we already have ready.
I have the following configuration in AS53xx:
controller E1 0
framing NO-CRC4
clock source line primary
ds0-group 4 timeslots 3-6 type r2-digital r2-compelled ani
Thanks in advance.
Henrry,
you need to have some information before you configure it. (this is just the most visible)
for PGW:
topology: is it a F-Link for example?
Your point code
Partner Point code for APC and for DPC
timeslot for the signaling link (supposing you use integrated SLT)
CICs available to be configured and how is the sequence to configure it in association with the timeslots?
what is the ISUP version?
for AS5400 (as an integrated SLT)
what is the timeslot for the signaling link?
how you want to group the E1s and how many are them?
Than you can study integrated SLT configuration documentation to prepare this config, but it is a complex job to do in the first time.
it depend on many things.
daniel
henrry.huaman Wed, 09/24/2008 - 14:29
Thanks Daniel,
AS54xx is only Gateway: attachment the configuration, the rlm group is up;
The message en PGW is:
"mss1masig:CIC=1,PST=OOS,CALL=IDLE,BLK=MATE_UNAVAIL"
"mss1masig:CIC=2,PST=OOS,CALL=IDLE,BLK=MATE_UNAVAIL"
"mss1masig:CIC=3,PST=OOS,CALL=IDLE,BLK=MATE_UNAVAIL"
"mss1masig:CIC=4,PST=OOS,CALL=IDLE,BLK=MATE_UNAVAIL"
any suggestions?
Thanks in advance.
Henrry,
the signaling link is up and running? is it in a separated SLT?
meanwhile:
check if RLM port is 3000/3001 at PGW config file. if not, in the rlm config, you need to add:
rlm group 1
protocol rlm port xxx
where xxx is the port to communicate. if it is 3003 at PGW, xxx will be 3002.
add global config parameter:
isdn switch-type primary-ni
can you change controller 6/0 to this configuration:
controller E1 6/0
framing NO-CRC4
pri-group timeslots 1-31 nfas_d primary nfas_int 0 nfas_group 0 rlm-group 1
this will create a dchanel:
interface Dchannel6/0
no ip address
encapsulation hdlc
isdn timer T310 60000
isdn incoming-voice modem
no isdn send-status-enquiry
isdn send-alerting
isdn negotiate-bchan resend-setup
isdn bchan-number-order ascending
no cdp enable
regards,
Daniel
