2800 configuration advnaced software
Sep 23rd, 2008
I'm trying to use the configuration tool to design a few 2811 routers with the VPN option as well as mutiple T1 connections. I've been searching but I cannot find any information on which advanced featureset I would need to include in the configuration for the router. Any ideas?
satish_zanjurne Tue, 09/23/2008 - 21:28
  • Silver, 250 points or more
"ADVANCED IP SERVICES" fetaure set is suitable.
In this you will get
IPv6 , Advanced Security , Service Provider Services , Cisco IOS Firewall , IPSec, 3DES,VPN,SSH,MPLS , ATM, VoIP,IP Telephony.
HTH...rate if helpful..
