FWSM failover question
Sep 23rd, 2008
Hello, all!
I have a pair of cat65xx with ws-svc-fwm module installed in each. Both modules are running version 2.3(4). Failover was set up on modules.
I've got following output from show failover:
FWSM# sh failover
Failover On
Failover unit Primary
This host: Primary - Standby
Other host: Secondary - Active
Stateful Failover Logical Update Statistics
Link : fo-data Vlan 995
Stateful Obj xmit xerr rcv rerr
General 640440 0 632804 0
sys cmd 632714 0 632714 0
up time 0 0 0 0
RPC services 858 0 0 0
xlate 0 0 0 0
TCP conn 289461409 0 1658093 0
UDP conn 0 0 0 0
ARP tbl 5313 0 76 0
RIP Tbl 0 0 0 0
L2BRIDGE Tbl 0 0 0 0
Xlate_Timeout 1555 0 14 0
TCP NPs 581795264 0 8071343 4523030
UDP NPs 39871943 0 240369 4523030
There are a lot of receive errors (rerr) for counters TCP NPs and UDP NPs. Unfortunately I was not able to find neither good description for the counters, nor any reason why the counters grow.
Can anybody give me some glue about counters or errors?
With best regards,
Maxim Zimovets
satish_zanjurne Wed, 09/24/2008 - 05:02
Hope you must have checked, whether interface connecting 2 65XX are error-free !!!!
Maxim Zimovets Wed, 09/24/2008 - 22:14
Yes. All interfaces are fine.
There are not any errors neither between switches, nor on interfaces to the modules.
All I can see is mentioned errors in show failover's output.
