adsl wic in 2811 as backup to primary frame-relay link
Sep 24th, 2008
I currently have a 2811 router with a ADSL module installed as a backup link to a Frame-relay service. I'm trying to find a sample configuration that will allow me to configure the adsl module to connect to a pix501 on loss of the frame-relay service,
regards,
Phillip
ohassairi Wed, 09/24/2008 - 01:47
  • Silver, 250 points or more
you said : " ...the adsl module to connect to a pix501 "
that's strange: adsl modules connect normally to ISP. only ethernet ports can connect to pix.
ppakime12 Wed, 09/24/2008 - 14:10
apologies, yes the adsl module would connect to an ISP. Then a VPN would be established to our pix501 which also has an external connection to the internet.
