Trouble with IP address assignment
Sep 24th, 2008
have the following config and I can not get the client to pull an ip address
crypto pki trustpoint dc-ho1
enrollment mode ra
enrollment url http://10.10.20.2:80/certsrv/mscep/mscep.dll
serial-number none
fqdn HOEDTVPN.edt.net
ip-address none
password xxx
subject-name O=EDT, OU=VPN, C=US, ST=Tx
revocation-check crl
rsakeypair HOEDTVPN.edt.net
auto-enroll
crypto pki certificate map cert_map 10
subject-name co ou = vpn
crypto isakmp policy 1
encr 3des
crypto isakmp client configuration group VPN
dns 10.10.20.2
wins 10.10.20.2
domain edg.net
pool hoedtvpn
acl 101
netmask 255.255.255.128
crypto isakmp profile VPN_client
ca trust-point dc-ho1
match certificate cert_map
client configuration address respond
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map vpnclient 20
set transform-set ESP-3DES-SHA
crypto map vpnmap1 local-address GigabitEthernet0/1
crypto map vpnmap1 client configuration address respond
crypto map vpnmap1 20 ipsec-isakmp dynamic vpnclient
interface GigabitEthernet0/1
description External Interface
ip address 64.XX.XX.XXX 255.255.255.248
ip access-group 111 in
duplex auto
speed auto
media-type rj45
crypto map vpnmap1
ip local pool hoedtvpn 10.20.90.1 10.20.90.126
access-list 101 permit ip 10.0.0.0 0.0.0.255 10.20.90.0 0.0.0.127
access-list 111 remark SDM_ACL Category=17
access-list 111 remark Auto generated by SDM for NTP (123) 10.10.20.2
access-list 111 permit udp host 10.10.20.2 eq ntp host 64.XX.xx.XXX eq ntp
access-list 111 permit udp any any eq isakmp
access-list 111 permit udp any any eq non500-isakmp
access-list 111 permit icmp any any
access-list 111 permit tcp any any eq 22
access-list 111 permit tcp any any eq telnet
access-list 111 permit gre any any
access-list 111 permit esp any any
access-list 111 permit tcp any any eq 10000
If I assign the pool directly under isakmp it will work but does not provide the other needed attributes, dns, wins ect.
when debug I get
Sep 23 14:48:24.090: ISAKMP:(7177):attributes sent in message:
Sep 23 14:48:24.090: Address: 0.2.0.0
Sep 23 14:48:24.090: ISAKMP:(7177):No IP address pool defined for ISAKMP!
Sep 23 14:48:24.090: ISAKMP:(7177):peer does not do paranoid keepalives.
Sep 23 14:48:24.090: ISAKMP:(7177):deleting SA reason "Fail to allocate ip address" state (R) CONF_ADDR (peer 24.XXX.XX.XX)
any ideas?
