What causes the "False carrier errors" counter to increment?
Sep 24th, 2008
on several 2950 Catalysts I see on most interfaces that the "False carrier errors" is counter rather high. The rest of the counters look allright to me.
Port configuration is as follows:
interface FastEthernet0/2
switchport access vlan 5
switchport mode access
speed 100
duplex full
no snmp trap link-status
spanning-tree portfast
spanning-tree bpduguard enable
This is the output you get from the "show controllers ethernet-controllers" command:
Transmit FastEthernet0/2 Receive
709814271 Bytes 2445719693 Bytes
392128521 Frames 90436937 Frames
158965864 Multicast frames 1 FCS errors
54959496 Broadcast frames 3546 Multicast frames
0 Pause frames 114443 Broadcast frames
0 Single defer frames 0 Control frames
0 Multiple defer frames 0 Pause frames
0 1 collision frames 0 Unknown opcode frames
0 2-15 collisions 0 Alignment errors
0 Late collisions 0 Length out of range
0 Excessive collisions 5 Symbol error frames
0 Total collisions 1049 False carrier errors
0 Control frames 0 Valid frames, too small
2 VLAN discard frames 0 Valid frames, too large
0 Too old frames 10 Invalid frames, too small
0 Tagged frames 0 Invalid frames, too large
2 Aborted Tx frames 0 Discarded frames
mfreijser Wed, 09/24/2008 - 04:56
  • Bronze, 100 points or more
Here's a quote from the Switch Command Reference which describes the "False Carrier Errors" counter. It doesn't give much information, but maybe it helps!
"The number of occurrences in which the interface detects a false carrier when frames are not sent or received."
I can't find any more information on the web about the errors, and i haven't seen the errors before so i can't tell you more about it.
Michael
Beat.Traber Wed, 09/24/2008 - 05:02
Thanks Michael
This was as far as I got - and to be honest I can't make out what Cisco means by a "false carrier". Since the interface is configured full duplex there is no CSMA/CD in use. And the rest of the error counters look (almost) zero to mee.
I'd been searching the web too, but didn't find anything useful.
Thanks anyway
Leonardo Schieder Tue, 03/06/2012 - 06:32
Could it be that the PC's interface is not set to FULL/100, but to Auto/Auto?
I'm also looking for the detailed meaning of "False Carrier Errors"...
Beat.Traber Mon, 03/12/2012 - 05:08
Leonardo,
If the end device's interface is in Auto mode and the switch interface is fixed, you will see errors on the switch's receive counter (Alignment errors, FCS Errors, Collision Fragments). This I had already verified.
The False Carrier Error must be triggered by something else. So, having posted my original question in 2008 I'm still none the wiser.
