09-24-2008 05:01 AM
Is it possible to configured policy based routing either on Pix or ASA? If so I wanted to know the commands or the link where I can able to go through before implementing them on live.
09-24-2008 05:21 AM
Anand,
I don't believe that Policy Based Routing is supported on the PIX/ASA platforms. Also, don't get confused when you see the "route-map" command option in PIX 6.3 and higher. This command is applicable only when redistributing routes into OSPF.
HTH,
Mark
09-24-2008 05:22 AM
Thanks for the confirmation :-)
09-24-2008 05:26 AM
No problem! I wish it was supported or will be available in an upcoming release.
Mark
