7301 Router %Error in authentication
Sep 24th, 2008
When I try and go into enable mode I enter the password and I get %Error in authentication. Any thoughts? I was in the router eailier and used the same password as I am now and it worked no problem.
Mike
John Blakley Wed, 09/24/2008 - 05:47
You may have to reset it. What was the last thing you did it it, and are you consoled or terminaled into it?
John
John Blakley Wed, 09/24/2008 - 05:48
Oh, and I meant reset the password on the router if you can't get into it.
burleyman Wed, 09/24/2008 - 05:58
I tried both telnet and console both with the same results. The last thing I did was to show int and show run....I did not change or save anything.
Mike
