IPCCx 5.0(2) HA Redundant Server Installation
Sep 24th, 2008
I have installed IPCCx 5.0(2) First node and Failover node, the installation was suceessful and i can see all the CTI ports are registered with CallManager for both First and Failover nodes.Also I have created a trigger to test the test script and it was working fine .Inorder to test the Failover process I have switch off the First node and tested the script but its giving busy tone.how i can troubleshoot this problem?
please advice me...
daljeetsingh1_2 Wed, 09/24/2008 - 09:08
Hello
Please make sure you have the your test scripts and the required prompts in both the servers.
If the script & prompts are also in the 2nd node than it should work,
Chk the MIVR logs when you call the trigger pt in the failover scenario
HTH..
