Outside address for L2L
Sep 24th, 2008
Im trying to setup a L2L VPN between 2 ASA.
ASA at site A has a public IP address.
At site B, instead, the ISP router forwards all the incoming traffic for a pool of public IP addresses to a group of private addresses configured on the ASA.
I wish to use one of these IP addresses for a L2L VPN between the 2 sites.
The doubt i have is which IP address should i specify for the tunnel.
So far i used a private IP address as L2L peer, however apparently it doesn't work.
Does anybody can give me some feedback about the config?
acomiskey Wed, 09/24/2008 - 07:47
In site A, you definitely need to use the public ip address that the router is natting the Site B ASA to. If you don't have one you could use the public ip of the router and forward to the outside of ASA.
crypto map OUTSIDE 20 set peer
tunnel-group type ipsec-l2l
tunnel-group ipsec-attributes
pre-shared-key *
Option 2 would be to create a dynamic tunnel where no peer address is specified in Site A ASA. In this case you would do this...
tunnel-group DefaultL2LGroup type ipsec-l2l
tunnel-group DefaultL2LGroup ipsec-attributes
pre-shared-key *
Carlo Zaina Thu, 09/25/2008 - 06:49
If i have understood:
- at site-A is necessary
nat (inside) 0 access-list #interesting traffic to site B#
no global (outside) statement? or do i need a global statement in order to have private network traffic traversing the public network?
at site B:
same question, except i will use tunnel-group with the public ip address.
Furthermore: should i use the ip address of outside interface or for the tunnel peer?
I mean: site A has ip 82.x.y.z on the outside, however the hosts are natted to 82.x.y.w.
