Dial-Peer Voice x Voip
Sep 24th, 2008
How do you does with dial-peers voip to ccm servers? In the cluster with 5 servers, you create 5 dial-peers voip (incoming) to each servers, or there is another way to do?
Overall Rating: 5 (2 ratings)
jbarcena Wed, 09/24/2008 - 07:54
  • Red, 2250 points or more
Yes, use the same dial-peer changing the session target and the preference.
pgcristovam Wed, 09/24/2008 - 08:24
Yes, I known
I want to known if there is another way... similiar to trunkgroup....
Jaime Valencia Wed, 09/24/2008 - 08:47
  • Cisco Employee,
  • Hall of Fame,
    2011
no other way, one dial-peer per CUCM server with higher preference
java
if this helps, please rate
