Sep 22 06:58:19: %C6K_POWER-SP-4-PD_NOLINKUP: The device connected to 9/2 i
Answered Question
Sep 24th, 2008
Hi all,
We have 6509 and sh logs show
Sep 22 07:00:54: %C6K_POWER-SP-4-PD_NOLINKUP: The device connected to 9/2 is powered up but its link is not up in 5 seconds. Therefore, power is withdrawn from the port.
Sep 22 07:01:05: %C6K_POWER-SP-4-PD_NOLINKUP: The device connected to 9/2 is powered up but its link is not up in 5 seconds. Therefore, power is withdrawn from the port.
Sep 22 07:01:15: %C6K_POWER-SP-4-PD_NOLINKUP: The device connected to 9/2 is powered up but its link is not up in 5 seconds. Therefore, power is withdrawn from the port.
Sep 22 07:38:47: %C6K_POWER-SP-4-PD_NOLINKUP: The device connected to 9/2 is powered up but its link is not up in 5 seconds. Therefore, power is withdrawn from the port.
Sep 23 07:17:11: %C6K_POWER-SP-4-PD_NOLINKUP: The device connected to 9/14 is powered up but its link is not up in 5 seconds. Therefore, power is withdrawn from the port.
Sep 23 07:17:26: %C6K_POWER-SP-4-PD_NOLINKUP: The device connected to 9/14 is powered up but its link is not up in 5 seconds. Therefore, power is withdrawn from the port.
Sep 23 07:17:36: %C6K_POWER-SP-4-PD_NOLINKUP: The device connected to 9/14 is powered up but its link is not up in 5 seconds. Therefore, power is withdrawn from the port.
Sep 23 07:17:46: %C6K_POWER-SP-4-PD_NOLINKUP: The device connected to 9/14 is powered up but its link is not up in 5 seconds. Therefore, power is withdrawn from the port.
Sep 23 07:17:56: %C6K_POWER-SP-4-PD_NOLINKUP: The device connected to 9/14
Any idea ?
both p[orts are connected now
thanks
mahesh
Correct Answer by Calin Chiorean about 8 years 7 months ago
Hello!
This message indicates that the system withdrew the power that was allocated to the specified port because the port link was not operational in the specified number of seconds.
Can you connect the device to another port to see if the same behavior re-appear? Or connect another device to 9/14 to see if you have the same issue.
The idea is to identify on which side is your problem, and then you can troubleshoot some more.
Cheers,
Calin
Overall Rating: 5 (1 ratings)
Correct Answer
Calin Chiorean Wed, 09/24/2008 - 11:18
  • Silver, 250 points or more
Hello!
Cheers,
Calin
