ACS Express selection rules
Sep 24th, 2008
Have anyone experience about the selection rule?
My problem is:
I've two policy against the same group device:
One use active dir database and PEAP method and the second use local database and eap fast (wifi phone)
How I can discriminate the authentication because if I connect in peap and the first polici is for peap work fine but the wifi phone does not work.
If I put the first policy for eap-fast the wifi phone work fine but the peap device doesn'work.
I thin that the problem is to identify the correct attribute but I'm not able to do.
thanks a lot
