09-24-2008 08:20 AM - edited 03-06-2019 01:34 AM
Hello guys, is there anyone in here that can help me with an issue that i am having trying to set up my new 837 router to Eircom ISP. I have got the settings but it does not work for me, is there anyone that can help with this problem?? please
Solved! Go to Solution.
09-25-2008 08:25 AM
Hi Mat,
I've used the config below with Eircom. You'll need to tidy up the NAT bits...
Kevin
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/0/0.1 point-to-point
pvc 8/35
pppoe-client dial-pool-number 1
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
ip virtual-reassembly
zone-member security Outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname eircom
ppp chap password 0 broadband1
ppp pap sent-username eircom password 0 broadband1
09-25-2008 05:57 AM
Eircom are fans of PPPoE rather than the PPPoA (Generally used) elsewhere in the UK, which is the biggest catch with them I find. There is a pretty good online config here:
http://www.alandoherty.net/cisco/eircom-dsl-with-esat-isdn-backup-config.txt
Courtesey of Alan Doherty.
However if you want to post your config up (less passwords) then I can take a look and see if I can spot the issue.
Mat
09-25-2008 08:25 AM
Hi Mat,
Kevin
interface ATM0/0/0
no ip address
pvc 8/35
interface Dialer0
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
