Warning message
Callmanager Express SIP Trunk to service provider DTMF issue
Sep 24th, 2008
we have cisco call manager express with a sip trunk to a service provider.
all calls work
dtmf internal to internal works
dtmf external to internal works
dtmf internal to extenal does not work.
has anyone done anything like this and is it possible on express?
jbarcena Wed, 09/24/2008 - 08:42
  • Red, 2250 points or more
What type of dtmf are you using on your dial-peer?
Could you please upload your show run?
cmelbourne Wed, 09/24/2008 - 11:40
see config below.
voice-card 0
no dspfarm
voice call carrier capacity active
service pots
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
redirect ip2ip
fax protocol pass-through g711alaw
h323
h225 signal overlap
modem passthrough nse codec g711ulaw
sip
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
voice register global
mode cme
max-dn 144
max-pool 36
date-format D/M/Y
call-forward system redirecting-expanded
create profile sync 0087542630484407
voice register dn 1
interface FastEthernet0/0
ip address 10.17.49.4 255.255.255.0
ip nat inside
interface Service-Engine0/0
ip unnumbered FastEthernet0/0
service-module ip address 10.17.49.5 255.255.255.0
service-module ip default-gateway 10.17.49.4
interface FastEthernet0/1
ip address x.x.x.x
ip nat outside
ip http server
ip http secure-server
ip http path flash:/gui
ip nat inside source list 100 interface FastEthernet0/1 overload
access-list 100 permit ip any any
access-list 100 permit tcp any any
access-list 100 permit udp any any
access-list 100 permit icmp any any
access-list 100 permit esp any any
access-list 100 permit gre any any
voice-port 0/0/0
voice-port 0/0/1
disconnect-ack
compand-type a-law
cptone GB
--More-- station-id name "MODEM"
station-id number 2288
voice-port 0/0/2
voice-port 0/0/3
mgcp
mgcp dtmf-relay voip codec all mode out-of-band
mgcp package-capability fm-package
dial-peer voice 40 voip
description *AUTOATTENDANT*
destination-pattern xxxxxxx
redirect ip2ip
b2bua
voice-class codec 1
session protocol sipv2
session target ipv4:10.17.49.5
dtmf-relay rtp-nte
--More-- no vad
dial-peer voice 41 voip
description *PromptMGM*
destination-pattern 2199
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 3001 pots
answer-address 2288
destination-pattern 2288
fax rate disable
port 0/0/1
dial-peer voice 1001 voip
description SIP TRUNK
--More-- translation-profile incoming prefix
translation-profile outgoing out
destination-pattern .T
redirect ip2ip
b2bua
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
session target ipv4:x.x.x.x:5060
session transport udp
dtmf-relay rtp-nte
fax rate 14400
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
ip qos dscp cs5 media
ip qos dscp cs4 signaling
randy.poteat@t-... Thu, 10/02/2008 - 05:07
We have had success adding dtmf-relay sip-notify h245-alphanumeric to the outgoing dialpeers.
