cisco unified communication 520
Sep 24th, 2008
Please find the attached detail of Our scenario:
we have following devices
1.uc520
2.cisco 2924 Switch
3.Two analouge phone lines came from PBX
4.Rightfax server
5.two cisco ip phones
We want to send Fax over Ip with the help of uc520 for both inbound and outbound.
Currently I am using Cisco Configuration Assistant in keysystem mode and plug analouge phone line in fxo port which comes from PBX.
Now i can call outbound with cisco IP phones.Next steps are
1.connect to right-fax server to UC500
2.fax out to PSTN through the servers
then receive the fax from PSTN on the right-fax server
Rightfax server is a Ip fax server and we are using it as a virtual server and it connects with a cisco switch and rightfax server support T.38 and SIP.DHCP should be disabled on uc520 because in our network already one DHCP is running.
Does any one have idea how to do that ?
vmoopeung Tue, 09/30/2008 - 07:51
  • Bronze, 100 points or more
You may try disabling the data dhcp on the UC520 using the command “No ip dhcp pool data”.
