Arp timeout?
John Blakley
Is there a way of changing the refresh time on the arp cache? We had a situation today where a VM failed over, and the other VM wasn't seen until I cleared the arp table on the switch. Is this a configuration problem with the switch or the VM?
This is a 3750
Thanks!
John
HTH, John *** Please rate all useful posts ***
Giuseppe Larosa
Hello John,
the default arp timeout is 4 hours but it can be changed
go on interface config and use arp timeout command
other thought:
check if the VM can send a gratuitos ARP when starting to work.
this is used for example when cisco routers running HSRP the new active router sends a gratuitos ARP to refresh the arp and cam tables.
Hope to help
Giuseppe
