VXML Documents
Sep 24th, 2008
Hi: I posted this conversation in the developer forum, but I can see it, so, I post again here.
CVP Call server 4.0.2
ICM 7.2
Comprehensive Call Flow
Hi:
I don't have the license for the VXML Server yet, so, I decide to implement my own VXML Server. I set the Run External Script node on ICM to hit my Internet Information Server, then, my web server has to return a VXML Document (exactly as the VXML Server do)
So,
1) I would need a sniplet of VXML Document generated when you invoke the VXML Server from the ICM Script using the Run External Script node.
In the VXML Studio I know you have to start with a Subdialog_Start and end with a Subdialog_Return. Well, I need the VXML document generated by these steps.
2) I tested return from my web server the following XML.
(Monitoring the script on the ICM it has no return error, but it does not go to the following node. I suppose because it does not have the subdialog return code.
I love if someone can tell me how to modify this XML to makes it work.)
<?xml version="1.0" encoding="iso-8859-1"?>
<vxml version="2.0">
<form id="CustomerVXML" scope="dialog">
<block>
<prompt bargein="true">
<audio src="http://192.168.31.50:7000/CVP/audio/helloworld_audio.wav" />
</prompt>
</block>
<catch event="error.badfetch">
<return event="error.badfetch"/>
</catch>
<catch event="error.semantic">
<return event="error.semantic"/>
</catch>
<catch event = "error.unsupported.format">
<return event="error.unsupported.format"/>
</catch>
<catch event = "error.unsupported.element">
<return event="error.unsupported.element"/>
</catch>
<catch event="telephone.disconnect.hangup">
<return event="telephone.disconnect.hangup"/>
</catch>
<catch event="error">
<return event="error"/>
</catch>
<block>
<return/>
</block>
</form>
</vxml>
thank you in advance,
marcelo
