Does the below OSPF Summarization have any meaning..?
Sep 24th, 2008
Hi All,
OSPF config on one of the routers..
router ospf 100
log-adjacency-changes
area 0.0.0.0 range 10.40.11.0 255.255.255.252
area 0.0.0.0 range 10.60.0.0 255.255.0.0
area 0.0.0.0 range 10.100.10.4 255.255.255.252
area 0.0.0.0 range 10.233.233.0 255.255.255.0
area 0.0.0.0 range 6.9.5.0 255.255.255.192
area 0.0.0.0 range 6.9.5.64 255.255.255.192
area 0.0.0.0 range 6.9.5.128 255.255.255.192
area 0.0.0.0 range 6.9.5.192 255.255.255.192
area 0.0.0.0 range 192.168.100.0 255.255.255.0
area 0.0.0.0 range 192.168.109.0 255.255.255.0
area 0.0.0.0 range 192.168.111.0 255.255.255.0
area 0.0.0.0 range 192.168.160.0 255.255.255.0
redistribute connected
redistribute bgp 65529
network 10.40.11.0 0.0.0.3 area 0.0.0.0
network 10.50.10.0 0.0.0.3 area 0.0.0.50
network 10.60.0.0 0.0.255.255 area 0.0.0.0
network 10.100.10.4 0.0.0.3 area 0.0.0.0
network 10.233.233.0 0.0.0.255 area 0.0.0.0
network 6.4.5.0 0.0.0.63 area 0.0.0.0
network 6.9.5.64 0.0.0.63 area 0.0.0.0
network 6.9.5.128 0.0.0.63 area 0.0.0.0
network 6.9.5.192 0.0.0.63 area 0.0.0.0
network 192.168.100.0 0.0.0.255 area 0.0.0.0
network 192.168.109.0 0.0.0.255 area 0.0.0.0
network 192.168.111.0 0.0.0.255 area 0.0.0.0
network 192.168.160.0 0.0.0.255 area 0.0.0.0
distance ospf external 220
As the summarized entries are same as 'network' statement, I think the summarized stmts are not needed.
Is that correct..?
Thank you
MS
Overall Rating: 3.8 (5 ratings)
Giuseppe Larosa Wed, 09/24/2008 - 12:04
  • Hall of Fame,
    Founding Member
Hello Mehboob,
the network command can work as an acl statement so you should verify if the ip addresses configured on the router interfaces are more specific then the network statements the area range are effective.
If the interfaces match the network commands I agree the area range are useless
Hope to help
Giuseppe
Jon Marshall Wed, 09/24/2008 - 12:15
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
MS
I agree with what Guiseppe has said but you need to make sure that you have interfaces on the router for all the network statements.
Because the network statement under OSPF is used to tell the router which interfaces to start on rather than which networks to advertise you need to make sure each network statement corresponds to an interface.
If it doesn't and you remove the corresponding area range command then you stop advertising one of the summary ranges.
Jon
wilson_1234_2 Fri, 09/26/2008 - 13:16
Jon,
Can you explain this?:
"Because the network statement under OSPF is used to tell the router which interfaces to start on rather than which networks to advertise"
What do you mean by "start on"?
Jon Marshall Fri, 09/26/2008 - 13:26
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Wilson
I was differentiating between the function of the network statement under BGP and the function under OSPF/EIGRP etc.
router bgp 64521
network 192.168.10.0 mask 255.255.255.240
the above tells BGP to advertise this network to any of it's peers
router ospf 1
network 192.168.10.0 0.0.0.15
this does not tell OSPF to advertise this network to it's peers. What it does is tell OSPF to start OSPF on any interface that falls under the above range. So if on the same router there was the following
int fa0/0
ip address 192.168.10.1 255.255.255.0
then the OSPF config "network 192.168.10.0 0.0.0.15" covers this address ie.
192.168.10.0 0.0.0.15 = 192.168.10.1 -> 192.168.10.15
192.168.10.1 falls within the above range so OSPF starts up on int fa0/0 and will form adjacencies/neighborships with any other routers with interfaces on that subnet running OSPF.
Note that when OSPF starts it sends an advertisement for 192.168.10.0 255.255.255.0 which is the actual subnet mask allocated to the interface and not the subnet mask 0.0.0.15 = 255.255.255.240 configured under router ospf.
Hope this makes sense.
Edit - see also this recent thread which also covers the same point -
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=WAN%2C%20Routing%20and%20Switching&topicID=.ee71a06&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cc1e1a6/6#selected_message
Jon
Richard Burts Fri, 09/26/2008 - 13:50
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Richard
If Jon had said "run on" rather than "start on" would it make any more sense to you?
Jon was addressing a fairly common misunderstanding of the use of the network command in OSPF (and other Interior Routing Protocols). The network statement does not tell OSPF what network to advertise but tells OSPF which interfaces to include in the protocol - or what interfaces to run on. When OSPF runs on an interface it looks at the address and subnet mask information and based on that OSPF decides what to advertise.
Rick
Richard Burts Wed, 09/24/2008 - 12:34
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
MS
There is not enough information here for us to know whether the summarization entries are needed or not. We would need interface information, especially the size of the subnets on the interfaces.
Clearly a couple of the area range statements are not needed: (area 0.0.0.0 range 10.40.11.0 255.255.255.252 and area 0.0.0.0 range 10.100.10.4 255.255.255.252) since it would be impossible to be summarizing subnets with this.
The fact that the size is the same on the network statement and on the area range does suggest that area range may not be changing much of anything. But it does not proove it. For example the network statement of:
might match a single interface with a /24 subnet on it and the area range is not needed. But what if there were 4 interfaces with subnets of 10.233.233.0/26, 10.233.233.64/26, 10.233.233.128/26, and 10.233.233.192/26. In that case the area range would be needed.
So while it does seem likely that the area range statements are not needed, we do not have enough information to know that for sure.
Rick
fortis123 Thu, 09/25/2008 - 06:14
Thank you all for the quick replies. here is more information...
This from one of #2-6513 which are core to the network.
Just as a note, the 2nd 6513 has a p2p gig connection to another location- a stub area.
2nd 6513:
router ospf 100
area 0.0.0.0 range 1.1.1.4 255.255.255.252
area 0.0.0.0 range 10.20.20.0 255.255.255.252
area 0.0.0.0 range 192.168.100.0/24
area 0.0.0.0 range 192.168.109.0/24
area 0.0.0.0 range 192.168.111.0/24
area 0.0.0.0 range 192.168.160.0/24
redistribute static
network 1.1.1.4 0.0.0.3 area 0.0.0.0
network 10.20.20.0 0.0.0.3 area 0.0.0.0
network 6.9.5.0 0.0.0.63 area 0.0.0.0
Below are the 'interface' infor ffrom one of the switches. As you can guess, other switch has similar with HSRP configs..
Also, no seperate interfaces existing for 6.9.5.X subnet.
interface Vlan11
ip address 192.168.100.2 255.255.255.192
interface Vlan12
ip address 192.168.100.66 255.255.255.192
interface Vlan13
ip address 192.168.100.130 255.255.255.192
interface Vlan14
ip address 192.168.100.194 255.255.255.192
interface Vlan15
ip address 192.168.111.2 255.255.255.0
interface Vlan16
ip address 192.168.160.2 255.255.255.0
interface Vlan25
ip address 10.60.25.2 255.255.255.0
interface Vlan100
ip address 6.9.5.2 255.255.255.0
interface Vlan101
ip address 10.60.101.2 255.255.255.0
interface Vlan109
ip address 192.168.109.2 255.255.255.0
interface Vlan110
ip address 192.168.110.2 255.255.255.0
interface Vlan121
ip address 10.60.121.2 255.255.255.0
interface Vlan151
ip address 10.60.151.2 255.255.255.0
Thank you
MS
Richard Burts Thu, 09/25/2008 - 11:56
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
MS
Thank you for providing the additional information. It shows quite a mixture:
- 2 summarizations are effective and do summarize several smaller prefixes
- 3 summarizations have exactly the same size as the subnets on the interfaces, so the summarization does no good (but are not broken or invalid)
- 4 summarizations are broken or invalid since they describe smaller pieces of a larger single subnet
- 2 of the summarizations are suspect since they describe address blocks that do not correspond to any interface on the router. If the addresses are learned from other routers these might possibly be valid
Also you comment that:"no seperate interfaces existing for 6.9.5.X subnet". But there is a subnet for 6.9.5
interface Vlan100
Rick
fortis123 Thu, 09/25/2008 - 13:30
Hi Rick,
Thank you for the great& detailed input. Got to score all you genius's at the end:-).
1.no seperate interfaces existing for 6.9.5.X subnet". But there is a subnet for 6.9.5
-->I should have phrased this in a correct way. I wanted to mention that interface ip created with /24 and in summarization it was broken in to 4, so this definitely does not sound correct.
2. area 0.0.0.0 range 1.1.1.4 255.255.255.252
1.1.1.4 : 1.1.1.5 / 30 : Ip for gig interface connceting to other location (ospf stub area)
10.20.20.0 : 10.20.20.1/30 : Ip for gig interface connecting to WAN router at this facility which in turn connects to satellite offices vis T1/ DS3s.
Any comments on this entries?
Also, not related to this query but related to config on same switches.. enabling BGP with some 'network' statements and 'NO' Established neighbour (Active or Never state) will do anything good..?
Thank you
MS
Richard Burts Thu, 09/25/2008 - 13:47
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
MS
1) We agree about this. There is a single subnet of /24 and the area range statements divide it into 4 parts. This is backwards. The area range is intended to aggregate smaller address blocks into larger address blocks and not to subdivide an address block.
2) if the subnets do exist then the area range command is not invalid or broken. But since it is using the mask 255.255.255.252 it is summarizing to a /30 which is the smallest mask and the area range command is not summarizing any address blocks.
We might need a little more information about the BGP to provide really good answers. I believe that you are saying that the BGP configuration does have some network statements and does have some neighbor statements. But that none of the BGP neighbors are established. If there are no established neighbors then the BGP is doing no real good. If a neighbor state is never then the configured neighbor has never established a BGP neighbor relationship. I would sure want to investigate and see why this has never worked. If the neighbor goes to active state then it implies that at some point the neighbor was working ok but that it is not working now. I would want to investgate and determine the reason that the neighbor can no longer become established.
If there are no established neighbors than the BGP is not doing any good at this time.
Rick
fortis123 Fri, 09/26/2008 - 05:25
Hi Rick,
Thank you very much for your quick reply. As far as BGP.. there are no 'Establised neighbors'. Not sure why these configs in place. Just to make my slef clear b4 taking them (entire BGP) out..
Core S1:
router bgp 65529
network 10.29.2.0 mask 255.255.255.0
network 10.29.4.0 mask 255.255.255.0
network 10.40.0.0 mask 255.255.0.0
network 192.168.29.0
network 192.168.100.0 mask 255.255.255.192
network 192.168.100.64 mask 255.255.255.192
network 192.168.100.128 mask 255.255.255.192
network 192.168.100.192 mask 255.255.255.192
neighbor 10.129.25.2 remote-as 65129 --> Used to be a neighbor and not anymore.
neighbor 6.2.17.1 remote-as 2506
neighbor 6.2.17.1 soft-reconfiguration inbound
ip bgp summary:
Neighbor up/down State/PfxRcd
10.129.25.2 16w1d Active
6.2.17.1 never Idle
Core S2:
router bgp 65030
network 172.16.30.0 mask 255.255.255.0
172.16.30.0/24 : IP space assigned for RA VPN cleints at another location (on VPN concentrator).
ip bgp summary:
Thank you
MS
Richard Burts Fri, 09/26/2008 - 12:23
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
MS
I would interpret this that sometime since the BGP process started (probably when the router booted) the neighbor at 10.129.25.2 has been established but it no longer is. I am not sure how to interpret your comment that it "Used to be a neighbor and not anymore". Is the not anymore just an acknowledgement that it is not working now or does it indicate that there is a reason why it should no longer be an established neighbor.
If the neighbor should be established and is not then some troubleshooting is called for. If neither neighbor is valid (should be establihsed) then there is no reason not to remove the BGP config.
On S2 if the config of BGP truly has no neighbor statements then I do not see any good that it could do and you should feel free to eliminate this.
Rick
fortis123 Mon, 09/29/2008 - 05:08
Hi Rick,
Thanks again for your reply.
10.129.25.2 :"Used to be a neighbor and not anymore". --> The rtr with this IP used to be BGP neighbor for the one of the core sw. That site was deco'ed later. So it looks like BGP can safely be re moved from these switches.
Thank you all for your time & valuable replies/suggestions.
regards
MS
Richard Burts Mon, 09/29/2008 - 08:43
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
MS
Yes it sounds like the BGP can be safely removed.
I am glad that my responses and suggestions have been helpful. Good luck with getting things updated.
Rick
