ASA in HA (Active/Standby failover) but only one IPS module
Answered Question
Sep 24th, 2008
Hi folks,
Will I have a chance to configure active/standby failover with a pair of ASAs but only one of them will have AIP-SSM module? I know it is a requirement that the two ASAs are exactly the same from HW and SW perspective, but not sure if that would include IPS module. Obviously IPS will not work if the primary device fails, but that's OK.
Hopefull
Eugene
Correct Answer by suschoud about 8 years 7 months ago
Unfortunately failover would not work with 1 ips module.
Either you should have two,oryou would need to remove one from asa.
Do rate helpful posts.
Sushil
Overall Rating: 5 (1 ratings)
Correct Answer
suschoud Wed, 09/24/2008 - 13:58
  • Gold, 750 points or more
Sushil
