UC520 language upgrade problem
ianwarb
Hi, I am trying to upgrade a UC520 with the GB language pack but it seems to constantly fail. It works through the various stages up to about stage eight then fails but I cannot see any reason for it. I am unzipping the CUE files into the default appdata/phoneloads directory and adding the GB.prt file but it will not upgrade, does anyone have any advice
thanks
ian
6 Replies 6
Rob Huffman
Hi Ian,
Just curious,are you using the special UC520 CUE files from this location?
UC520 CUE Localization Files
http://www.cisco.com/cgi-bin/tablebuild.pl/UC520-CUE-2.3.4
Rob
Hi Rob
yes, that is where I go the files. I have managed to do this now however I had to do it manually through the CLI and FTP/TFTP as CCA continually failed. I found an excellent document on Cisco Wiki support that took me through the process however this is a workaround not a resolution
thanks
Ian
Hi Ian,
Nice work my friend!
Do you mind posting up the Link to to doc you used so that it may help others in the future :)
Cheers,
Rob
Thanks Ian!
This type of kind consideration is what makes these Forums great. +5 points for your great help here :)
Take care,
Rob
jeff.heath
Ian,
I spent ages trying to get the langauge pack on to the box. The below is how I did it using ftp server and CLI.
Installing Cisco UC520 language files
1/ #service-module integrated-service-engine 0/0 session
2/# conf t
3/(config)# software download server url ftp://x.x.x.x. Username xxxx password xxxx (this creates a download server, x.x.x.x = ip address of you ftp server)
4/exit
5/# software install clean cue-vm.ise.3.0.3.pkg
6/# enter command 8
7/enter command x
Jeff
