Call Pickup
Answered Question
Sep 24th, 2008
CCM 5.1.1
IPCC 4.5(2)
I have two IPCC agents. If one of the agents has left their desk (and forgot to go not ready) the other agent would like to be able to pickup that call before the 4 rings that would normally send it to them. I have placed both agents into a call pickup group and it works for a while. Then they will try to pick up a call, the display will blink quickly on the phone they are trying to pick from, the person in the queue hears a half-second of silence and the call continues to ring on the original set. Has anyone come across anything like this before?? Can you not use "Call Pickup" within an IPCC queue?
Correct Answer by Rob Huffman about 8 years 8 months ago
Hi Keith,
Pickup is not supported for IPCC Agent phones;
Unsupported Actions for Cisco IP ICD Agents
Use of the following softkeys on a Cisco IP Phone is not supported:
•Barge
•cBarge
Unsupported and Supported Actions for Cisco ICD Agents
•DirTrfr
•GPickup
•iDivert
•Join
•MeetMe
•Park
•Pickup
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_3_5/release/notes/cra3.5.4/crs354rn.pdf
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Kenneth Mohammed Wed, 09/24/2008 - 13:52
  • Silver, 250 points or more
Hello Keith
Im not sure whether or not you can use call pickup with IPCC extensions, as I havent tested it, but try putting the actual CTI RP DN that forwards to IPCC in the call pickup group and see if that works.
Hope that helped
Correct Answer
Rob Huffman Wed, 09/24/2008 - 15:26
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Keith,
•Barge
•cBarge
•DirTrfr
•GPickup
•iDivert
•Join
•MeetMe
•Park
•Pickup
Hope this helps!
Rob
Rob Huffman Thu, 09/25/2008 - 07:58
  • Hall of Fame,
    Founding Member
Hi Keith,
You are most welcome my friend!
Cheers,
Rob
