global ( inside) and nat (inside)
Sep 24th, 2008
I have the flowing config
global (outside) 1 interface
global (inside) 1 interface
global (dmz) 1 interface
nat (dmz) 1 0.0.0.0 0.0.0.0
nat (dmz) 1 0.0.0.0 0.0.0.0 outside
Currently, DMZ users can access inside and outside via NAT
Once I add nat(inside) 1 0 0 , I can't access the inside PCs from DMZ.....I would like to allow inside users to go outside via nat(inside) and global(outside) ...any suggestions
I have asa 5505 ver 7.2(4).
You need to look at your NAT design, I would use something like:-
Global (outside) 1 interface
NAT (inside) 1 x.x.x.x y.y.y.y
NAT (DMZ) 1 w.w.w.w z.z.z.z
nat (inside) 0 access-list no-nat
nat (dmz) 0 access-list no-nat
access-list no-nat permit ip x.x.x.x y.y.y.y w.w.w.w z.z.z.z
access-list no-nat permit ip w.w.w.w z.z.z.z x.x.x.x y.y.y.y
x.x.x.x = Inside IP subnet
y.y.y.y = Subnet mask
w.w.w.w = DMZ IP Subnet
z.z.z.z = Subnet mask
The above will NAT the Inside to the outside using the firewall outside IP address.
It will nat the DMZ to the outside using the firewall outside IP address.
It will NOT nat the Inside to the DMZ
It will NOT nat the DMZ to the Inside
Is there a specific reason why you need to NAT from inside to dmz and dmz to inside?
HTH>
suschoud Thu, 09/25/2008 - 05:06
  • Gold, 750 points or more
Just remove :
Using :
no global (inside) 1 interface
everything should work just fine with ur config. then.
Do rate helpful posts.
Sushil
