ACS SE Patch upgrade
peterhkim
I'm trying to upgrde ACS SE.
Current: 4.1.3.12
trying to upgrade to 4.1.4.11
What will be the proper steps? Do I have to update with 4.1.4.1 first? Can I use the GUI to update?
Thanks.
Peter
smalkeric
Level 6
Level 6
Cisco supports the upgrade paths of versions:
• 4.1 to 4.1.4
• 4.1.2 to 4.1.4
• 4.1.3 to 4.1.4
You must have only ACS 4.1 installed before you install ACS 4.1.4. The installation instructions for ACS 4.1.4 are the same as for ACS 4.1
For information about installing ACS, refer to the below URL:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.1/installation/guide/windows/install.html#wp1041237
