FWSM and ASA configurations for Internal/Externally located 6.1 CM's
Sep 24th, 2008
We have an FWSM firewall (3.2.8) located at one location with a CM Pub on an inside subnet. In addition, we have a CM Sub located on an inside subnet of a remote ASA (8.0.4). Between the two locations are router based ipsec 3des vpn tunnels. The problem we are seeing is that database replication is not working between the two CM's.
ACL's on both FW's permit full ip between hosts, so the concern is that the FWSM and/or ASA Firewalls are reassembling fragmented packets and causing the DB connections to fail.
The MTU on the VPN routers (for the Tunnel interfaces) are set to 1420 and tcp mss set to 1300. In addition, both CM servers have the MTU adjusted down to 1400.
Packet captures on the FW's show that they are reassembling the fragmented packets (FW's are using default MTU of 1500).
Any non-intrusive configuration suggestions on the FW's to prevent the reassembly of the fragmented CM packets or to fix this DB connectivity problem? Also any other suggestions to address this problem would be helpful.
FYI the one way latency between CM's is <20ms (which is lower than the required 40ms min).
Thanks in advance,
-Scott
