caller-id enable reboots router
Sep 24th, 2008
Hello all
I am having this problem and I cannot figure out what is causing it. I have been searching for the last 2 hours trying to figure this out and hoping someone here can help.
Currently, I have a 1760 router with a vic2-4fxo card with 4 oots lines coming in. Everything is working fine in terms of calling, and call routing, but as soon as I turn on caller-id on one of the voice cards, the router immediately reboots. Not sure what is causing this, but I found a couple of forums that mentioned you need to change router from mgcp to h.323. I could not find how to do this, and thought someone here would be able to either help me wiht that, or make recommendations on what I am doing wrong. Any help you can give would be appreciated.
I am attaching my config thus far.
Nick
nickehunt Wed, 09/24/2008 - 16:22
here is my full config....
trunk group _POTS
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
bind control source-interface Loopback0
bind media source-interface Loopback0
header-passing
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
interface Loopback0
ip address 192.168.100.1 255.255.255.255
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.100.1
interface FastEthernet0/0.8
description Voice Vlan Interface
encapsulation dot1Q 8
ip address 192.168.8.1 255.255.255.0
ip helper-address 192.168.2.5
ip helper-address 192.168.2.4
tftp-server flash:P0030702T023.bin
tftp-server flash:P0030702T023.loads
tftp-server flash:P0030702T023.sb2
tftp-server flash:P0030702T023.sbn
control-plane
voice-port 2/0
voice-port 2/1
voice-port 2/2
voice-port 2/3
voice-port 3/0
trunk-group _POTS
echo-cancel coverage 32
connection plar opx 100
description inbound POTS line
voice-port 3/1
trunk-group _POTS
voice-port 3/2
trunk-group _POTS
voice-port 3/3
dial-peer voice 100 voip
preference 3
destination-pattern 1...
voice-class codec 1
session target ipv4:192.168.2.3
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 101 pots
trunkgroup TruArx_POTS
description Outbound calls to PSTN
preference 5
destination-pattern 9...........
progress_ind setup enable 3
progress_ind progress enable 8
dial-peer voice 110 voip
destination-pattern 210
session protocol sipv2
session transport tcp
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 111 voip
destination-pattern 211
dtmf-relay rtp-nte
codec g711alaw
sip-ua
mwi-server ipv4:192.168.2.3 expires 3600 port 5060 transport tcp
telephony-service
load 7960-7940 P0030702T023
max-ephones 24
max-dn 72
ip source-address 192.168.8.1 port 2000
auto assign 1 to 24
timeouts ringing 45
system message Phone System
dialplan-pattern 1 212555.... extension-length 4 no-reg
voicemail 210
max-conferences 8 gain -6
moh music-on-hold.au
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 200
secondary-dialtone 9
night-service day Mon 08:30 17:00
night-service day Tue 08:30 17:00
night-service day Wed 08:30 17:00
night-service day Thu 08:30 17:00
night-service day Fri 08:30 17:00
create cnf-files version-stamp 7960 Sep 23 2008 18:44:15
