IP Phone Reboots often
Anand Narayana
Level 6
Level 6
I have a remote site on which the IP phones keeps rebooting very often, I believe keepalive packets are losing often. Is there any tool where I can check what exactely causing this issue? because my Softphone works fine, but only the hard phones 7940/76960 keeps rebooting in the recent days, I have 15 IP phones in the remote location. Any help would highly appreciated.
6 Replies 6
Jaime Valencia
CUCM trace with keepalive option checked or a sniffer trace are the only ways
java
if this helps, please rate
java
How are they powered? That might be a symptom of an overloaded PoE switch.
I am in a similar position to the original poster of this question. Symptoms seem to only occur when a machine with a 10/100/1000 NIC is also in the loop.
How would you measure whether or not the PoE is overloaded? Do I really need to get the ampmeter out?
Reading around the 802.3af (2005) standard there seems to be a validation by the switch to see if power is needed. Apparently the circuit checks to see if the resistence on the circuit is between 15 and 33 kilo ohms. My current investigations are looking at whether or not the Gb NIC is adding resistence to the circuit.
I would interested to hear from anybody that may have had to measure this
bobsairam
Hi Aanand
All ip phones rebooting? What is the round trip .some time due to long round-trip delay /keep alive lost ,Check in CCM event logs for that phones
Which POE switch are you using? Check the logs of switch any issue in line power having issue.
If there is no logs related to inline power .Then check and upload the ip phone logs by browse the IP Phone ip .Also output of debug display option
*Hope this help*Pls rate it*
-Ranjan
Thanks for the suggestion, but I also did a firmware upgrade but still the phones keeps rebooting. I am using 3Com switch & I have connected a separate power adaptor too for the phones. Below is the output of the debug in the one of the IP phone. Rebooting happens when I try calling some extension or receiving calls, transfer & so on. Rating for the your answer will be depend with the suggestion you provide.
2008-10-01 14:44:09.400 Code:dd04, P:0, S:12300900
Phone Task Call Stack:
0009679a
0003aeb0
000460da
00046390
00044da8
System Regs: CPSR=2000003f
R0=d096eb14 R8=00000001
R1=000006cc R9=00400128
R2=00000000 R10=0000f0d0
R3=00000051 R11=736bdfdd
R4=0048585c R12=004ef13f
R5=2fab3a74 R13=0040dd48
R6=00485854 R14=000460df
R7=00000000 R15=000451e8
I still suggest that it is PoE related but do not know how to prove it.
In your situation activity on the phone could be putting additional load on the PoE circuit. The additional load then causes the amps, watts, volts, etc.. to drop below a tolerance threshold on the phone causing it to reboot. But this is all theory which I need help in proving/disproving.
