NTP Server ccm 5.1.1
Sep 24th, 2008
Hey All,
I'm just pre planning for a day lights saving time change in a voice environment. I'm curious, if the NTP server is set in a call manager cluster, are the end phones time dependent on the NTP servers time? or does a update need to be installed on the ccm?
Many Thanks,
bobsairam Wed, 09/24/2008 - 17:37
No Update required ,You can eneble DST on ccm 5.1.1
DST patch avilbale for only
Callmanagers do not have all timezones included in Date/Time Group Info
Need support for introduction of Western Australian Daylight Savings Info
Daylight saving does not work for non-TNP phones, Australia Info
Timezones in TypeTimeZone.csv have errors. Info
CDR Analysis and Reporting does not reflect DST changes for New Zealand
HTH ,Pls rate it
alanc3141592654 Wed, 09/24/2008 - 18:24
Thanks for your reply.
Day lights saving time has changed in au. So my concern is the time wont change on end user phones.
I'm thinking the times from the phones is received from the NTP servers configured in OS configuration?
bobsairam Wed, 09/24/2008 - 18:54
Need to reset the IP Phones.
For testing reset one phone and check the status
HTH * Pls rate it*
alanc3141592654 Wed, 09/24/2008 - 19:32
What information in the status of the phone is useful in regards to NTP server from the ccm cluster?
