QoS Configs WRR
Answered Question
Sep 24th, 2008
  • Blue, 1500 points or more
Today I applied some wrr-queuing commands to a gigabit interface on a 6748 1 G SFP card.
wrr-queue random-detect min-threshold 1 40 80
wrr-queue random-detect min-threshold 2 40 80
wrr-queue cos-map 1 2 2
wrr-queue cos-map 2 1 3 4
wrr-queue cos-map 2 2 6 7
OK, I applied it because the architectural group at the client has set such a standard for this particular type interface. When I add the configs, the router automatically added the same QoS configs to other interfaces on the card.
Is it because the card is divided into port groups that share the same queueing hardware?
I never saw this behavior before.
Victor
Correct Answer by andrew.burns about 8 years 10 months ago
Yes, it's documented (somewhat obscurely) here:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/qos.html#wp1481021
Basically, there are some commands (listed in the link above) which only apply to an ASIC and hence all the ports attached to that ASIC.
The "show interfaces capabilities" command will show which ports are on which ASIC.
Andrew.
Correct Answer by Prashanth Krishnappa about 8 years 10 months ago
Your understanding is correct. Since hardware resources are shared between ports, QoS configuration gets applied to all ports in the block(usually 12). You should have seen a message indicating so when you configured
Router(config-if)#interface gig2/13
Router(config-if)#wrr-queue cos-map 1 1 1
Propagating cos-map configuration to: Gi2/13 Gi2/14 Gi2/15 Gi2/16 Gi2/17 Gi2/18 Gi2/19 Gi2/20 Gi2/21 Gi2/22 Gi2/23 Gi2/24
Overall Rating: 5 (2 ratings)
Correct Answer
Prashanth Krishnappa Wed, 09/24/2008 - 18:51
  • Cisco Employee,
Correct Answer
andrew.burns Thu, 09/25/2008 - 00:15
  • Gold, 750 points or more
Andrew.
lamav Fri, 09/26/2008 - 00:34
OK, thanks folks. Appreciate the help...
Victor
