dhcp option 67
Sep 25th, 2008
I am trying to configure the option dhcp 67 on one of the cisco switches but I receive the error that the "dhcp doesnt allow raw option 67 "
Any idea?
thblake07 Fri, 10/03/2008 - 03:48
had the same problem. Installed 12.2(46)SE and was able to enter the option...unfortunately the DHCP Server doesn't seem to send option 67 or 66.
ip dhcp pool DATA
network 192.168.6.0 255.255.255.0
default-router 192.168.6.1
dns-server 192.168.5.23 192.168.6.1
netbios-name-server 192.168.5.23
option 43 hex 3a02.00c8.ff
ip dhcp pool VOICE
network 192.168.161.0 255.255.255.0
default-router 192.168.161.1
option 66 ip 192.168.7.21
option 43 hex 616c.6361.7465.6c2e.6e6f.652e.30
option 67 ascii "lanpbx.cfg"
Here is a capture from one of the dhcp packets:
Frame 198 (342 bytes on wire, 342 bytes captured)
Ethernet II, Src: Cisco_01:cd:c2 (00:1f:27:01:cd:c2), Dst: AlcatelB_78:75:8b (00:80:9f:78:75:8b)
Internet Protocol, Src: 192.168.161.4 (192.168.161.4), Dst: 192.168.161.58 (192.168.161.58)
User Datagram Protocol, Src Port: bootps (67), Dst Port: bootpc (68)
Source port: bootps (67)
Destination port: bootpc (68)
Length: 308
Checksum: 0x3c47 [correct]
Bootstrap Protocol
Message type: Boot Reply (2)
Hardware type: Ethernet
Hardware address length: 6
Hops: 0
Transaction ID: 0x72c3097a
Seconds elapsed: 0
Bootp flags: 0x0000 (Unicast)
Client IP address: 0.0.0.0 (0.0.0.0)
Your (client) IP address: 192.168.161.58 (192.168.161.58)
Next server IP address: 0.0.0.0 (0.0.0.0)
Relay agent IP address: 0.0.0.0 (0.0.0.0)
Client MAC address: AlcatelB_78:75:8b (00:80:9f:78:75:8b)
Server host name not given
Boot file name not given
Magic cookie: (OK)
Option: (t=53,l=1) DHCP Message Type = DHCP ACK
Option: (t=54,l=4) Server Identifier = 192.168.161.4
Option: (t=51,l=4) IP Address Lease Time = 1 day
Option: (t=58,l=4) Renewal Time Value = 12 hours
Option: (t=59,l=4) Rebinding Time Value = 21 hours
Option: (t=1,l=4) Subnet Mask = 255.255.255.0
Option: (t=3,l=4) Router = 192.168.161.1
Option: (t=43,l=13) Vendor-Specific Information
End Option
Padding
Why don't I see Option 66 or 67?
Cheers Tom
