WAAS and Microsoft Remote Assistance
Patrick Colbeck
Level 3
Level 3
My customer has an isse with WAAS and XP remote assistance. If they try it via IP address it works fine but via hostname it fails. Doing some investigation reveals that the two methods use different bind calls.
When using IP address to do the RPC bind
RPC: c/o Bind: UUID{000001A0-0000-0000-C000-000000000046}
DCOM-IRemoteSCMActivator
The auth type used is
Auth Type = 0A (RPC_C_AUTHN_WINNT - NT LAN Manager Security Support
Provider NTLM SSP).
This works
When a hostname is specified the auth
type used is
Auth Type = 09 (RPC_C_AUTHN_GSS_NEGOTIATE - Negotiates between the use
of the NTLM and Kerberos protocol SSP)
This fails.
A simialr thing seems to be affecting Microsoft SMS which again uses RPC.
They are using WAAS 4.1.1
Pat
Zach Seils
Level 7
Level 7
Pat,
Doesn't the Remote Assistance feature use RDP? What is the failure message you are seeing? What is the connection state (sh stat conn all) in WAAS?
Zach
Yes it does use RDP but it's not getting that far so far as I can see. Its failing to authenticate which it does before RPC binds RDP.
The customer has now logged this with TAC so I won't pursue it here. Thanks for replying though. I will post a summary of the solution when we have one so that if anyone searches for a similar problem they get an answer.
Hi Pat,
Just heard back from Engineering that they think this is bug CSCsu65835. Please follow through with your TAC case.
Zach
Thanks Zach I have passed this on to my customer. That looks like their issue and they are waiting for a release in which it is fixed.
Pat
