configuring Port-Channel on Cisco 3825
s-durando
Hi everybody,
does NM-2FE2W_V2 on Cisco 3825 support Etherchannel or 802.3ad?
Best regards
Stefano
satish_zanjurne
Level 4
Level 4
Hi ,
12.4 IOS starting from IP BASE feature set does support Etherchannel - Flexible PAgP
Provides enhancements and new functionality to existing EtherChannel port bundling features, including non-contiguous port bundles, port bundles of up to eight ports, and port bundles across multiple modules
HTH..rate if helpful..
Thank you!
If I use on board GigabitEthernet interfaces it works.
If I use FastEthernet interfaces on NM-2FE2W_V2 it doesn't work.
Why?
One additional information:
on the other side of the Etherchannel I have a Cat 3750G-24TS. Is it possible to have the Etherchannel working with FastEthernet on router side and GigabitEthernet on switch side?
Many thanks
Stefano
