Warning message
RIPV2 Questions
Sep 25th, 2008
guys i have two questions about few config if someone can help me out......
if my interface is connected to another router interface (say a f ethernet) and ip address of that is 192.168.1.1 now if i want to disable summarization on interface the command is no auto summary
now if i put passive interface default (what does that do) secondly there is a neigbour command in ripv2? what does that do if i type neibour 192.168.1.1 (which is ip of my connected otehr router interface) what will that do.....guys i m v new to rip your help is needed...thanks
Overall Rating: 5 (2 ratings)
satish_zanjurne Thu, 09/25/2008 - 05:23
  • Silver, 250 points or more
1. passive-interface default
This will set all interfaces as passive by default.In RIP , passive interface means no routing updates will be sent on this interface.Then if you don't want a interface as passive , you need to go under that interface and use "no passive-interface"
2.neighbor
This command permits the point-to-point (nonbroadcast) exchange of routing information. When it is
used in combination with the passive-interface router configuration command, routing information can
be exchanged between a subset of routers and access servers on a LAN.
Multiple neighbor commands can be used to specify additional neighbors or peers.
It is of more use in LAN. Where , you have defined your only LAN interface of router as passive , but you want to update routing information to a router, which lies on same ethernet segment.
So even if you have defined fastethernet as passive , you will still be able to exchange routing information with 192.168.1.1
It is like making an exception for selected router in a subset of routers..
HTH..rate if helpful..
Giuseppe Larosa Thu, 09/25/2008 - 05:52
  • Hall of Fame,
    Founding Member
Hello Satish and Khan,
the no passive interface has to be given under router rip as the passive interface default
also the no auto-summary command is given in router rip context
neighbor
combined with passive interface instructs the router to send out its update as a unicast to the configured ip address(es) instead of using the 224.0.0.10 destination (RIPv2 multicast address).
Because RIPv2 misses a neighbor state machine two devices can exchange updates one sending unicast packets and the other multicast packets.
Hope to help
Giuseppe
satish_zanjurne Thu, 09/25/2008 - 06:52
hi Giuseppe ,
Myself was wrong in first point & you were precise in second point.
Thanks You..
