Cisco Re-Certification
Answered Question
Sep 25th, 2008
I just want to check if passing exam 642-105 will re-certify CCVP ?
Will it also Re-certify CCNA ?
Please confirm as I am having problems to varify this information.
Shaheen
Correct Answer by Brandon Buffin about 8 years 4 months ago
Shaheen/Rob,
I don't believe 642-105 will recertify CCVP/CCNA as this is not a professional level exam. If you look at the following link, this exam falls under the category "Additional Proctored Exams for Validating Knowledge (not for Cisco Career Certification".
http://www.cisco.com/web/learning/le3/le11/learning_all_certification_exams_list.html
Brandon
Overall Rating: 4 (3 ratings)
rob.huffman Thu, 09/25/2008 - 04:58
Hi Shaheen,
Yes, any 642 Level exam will recertify your CCVP and CCNA :)
Cisco Systems Announces Recertification Policy Update for Professional-Level Certification
Certification Holders Who Pass Any Professional Level Certification Exam Will Recertify Their Active CCNP, CCDP, CCIP, CCSP, or CCVP Certifications
SAN JOSE, Calif., August 15, 2006 - Cisco Systems® today announced that effective Aug. 18, 2006, individuals who hold an active Cisco® CCNP®, CCDP®, CCIPTM, CCSP®, or CCVP® certification will recertify their professional-level certifications when they pass any other Cisco professional-level certification exam. Certification holders will continue to re-certify their professional level certifications when they pass any CCIE written exam.
"The proliferation of advanced technologies such as network security has significantly increased the knowledge base required of networking professionals," said Don Field, director of certifications at Cisco. "The expanded professional level re-certification policy recognizes certification holders who have taken steps to diversify their networking knowledge and skills to keep pace with today's evolving networking environment."
Cisco requires that all professional-level certifications be re-certified every three years. This policy helps to maintain the integrity of Cisco certifications by verifying that those who hold active Cisco certifications possess up-to-date expertise.
http://newsroom.cisco.com/dlls/2006/prod_081506b.html
CCNP, CCDP, CCIP, CCSP & CCVP certifications Complete one of the following recertification options:
Pass any 642 exam that is part of the professional level curriculum after 01/01/06
Pass any current CCIE or CCDE written exam.
http://www.cisco.com/web/learning/le3/learning_about_recertication.html#ccnp_ccdp_ccip_ccsp_ccvp
http://www.cisco.com/web/learning/le3/le2/le37/le54/learning_certification_type_home.html
CCNA Recertificaton
CCNA certifications are valid for three years. To recertify, either pass the current CCNA exam, or pass the ICND2 exam, or pass any 642 professional level or Cisco Specialist exam (excluding Sales Specialist exams), or pass a current CCIE written exam.
http://www.cisco.com/web/learning/le3/le2/le0/le9/learning_certification_type_home.html
Hope this helps!
Rob
MUHAMMAD SHAHEEN Thu, 09/25/2008 - 07:50
Hi Rob/Brandon,
Thanks for your answers and this where I am confused and clarification. I hope someone can clarify this
.....it is listed under Specialist Certification Path
with no Prerequisites
......whatever Brandon said seems correct
......whatever Rob said seems correct
but I am very confused as it has course code 642-105 which also meet the requirements.
Can we have some more answers please ? possibily some Cisco Authentic source or may who have used this to re-certify CCVP/CCNP etc.
Shaheen
rob.huffman Thu, 09/25/2008 - 08:48
Hi Shaheen,
My sincere apologies my friend! I am going to have to go with my friend Brandon here (+5 points here buddy!)
Almost everything I sent was correct except for the fact that the 642-105 is not a Professional Level exam.
This line tells the story (as nicely noted by Brandon)
The 642 level exams would have to be part of one of tne Certification Tracks (CCNP,CCSP, CCVP etc)
Sorry for the confusion :( I should learn to read a little more carefully.
Rob
MUHAMMAD SHAHEEN Fri, 09/26/2008 - 00:59
Hi Rob/Brandon,
Many Thanks to both of you in clarifying this (you both deserved to be rated). Cisco should make a sensible decision to change all non-certification (like this exam codes) to something other than 642.
Shaheen
andymclaughlin Mon, 10/13/2008 - 06:21
Hi There,
I have a CCNA and passed 2 of the CCNP exams (BSCI/BCMSN).
If I pass a single CCVP exam, but not ALL the CCVP exams before June 2009, when the CCNA Voice is a prerequisite for the CCVP, will I have to do the CCNA Voice exam to get a CCVP after this date?
Brandon Buffin Mon, 10/13/2008 - 07:09
From my understanding, you would need to pass all of the CCVP exams before June 24, 2009 for the CCNA to count as the prerequisite to CCVP. After this date, you would need CCNA Voice before your CCVP would be valid.
http://ciscocert.custhelp.com/cgi-bin/ciscocert.cfg/php/enduser/std_adp.php?p_faqid=4320&p_created=1213317210&p_sid=QRqPAegj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9Mzg2LDM4NiZwX3Byb2RzPTAmcF9jYXRzPSZwX3B2PSZwX2N2PSZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PWNjbmEgdm9pY2U*&p_li=&p_topview=1
Hope this helps.
Brandon
