8.04 and ssh does not work through vpn
Sep 25th, 2008
Somehow after upgrading the ASA Cluster 5520 from 8.03 to 8.04, I am not able to get ssh sessions through the tunnel.
The handshake starts, and then it stops after a while, and the remote client does not get any packets through the tunnel.
I this a known bug ? Is there a workaround ?
I downgraded to 8,.03, and it worked fine, execpt for the security problems...
Overall Rating: 1 (1 ratings)
sadbulali Thu, 10/02/2008 - 10:44
  • Bronze, 100 points or more
The security appliance allows SSH connections to the security appliance for management purposes. The security appliance allows a maximum of 5 concurrent SSH connections per context, if available, with a maximum of 100 connections divided between all contexts.SSH is an application running on top of a reliable transport layer, such as TCP/IP, that provides strong authentication and encryption capabilities. The security appliance supports the SSH remote shell functionality provided in SSH Versions 1 and 2 and supports DES and 3DES ciphers
Refer the following url for more information on configuring SSH Access in ASA:
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/mgaccess.html#wp1042250
