ACS SE and NIC Cards
Answered Question
Sep 25th, 2008
After reading the documentation regarding the NIC cards on the ACS appliance it seems the both cant be used together. Can one be used as a management Interface like on CS-MARS and IPS? while the other performs its normal operation?
Correct Answer by Premdeep Banga about 8 years 7 months ago
unfortunately no, you can only use one NIC that too bottom NIC (NIC 1).
If you want such a feature, you may want to contact your AM, and go for a feature request on this product.
Prem
Please rate if it helps!
Overall Rating: 5 (1 ratings)
Correct Answer
Premdeep Banga Thu, 09/25/2008 - 13:34
  • Gold, 750 points or more
Prem
niall-wilkins Sat, 09/27/2008 - 18:55
One last question..........Whats the purpose of having two NIC's on the appliance if only one can be used?
Premdeep Banga Sun, 09/28/2008 - 07:34
future use/new feature/development. But currently it is not used
