Multilink PPP configuration problem in 2600 router with 12.0
Sep 25th, 2008
I m having cisco 2600 router with IOS version 12.0.. I need to configure multilink in my router having s0/0 and s0/1.. In my ISP they have configured like
RouterA(conf)#int multilink 3
and configured..
But in my router having only this option
RouterB(conf)#multilink bundle-name authenticated
how to configure both end.. because both end having different option to configure multilink..
pls provide any link to advantagres of multilink
How to configure in my router? what is the advantages of multilink? It is very urgent. Pls help
Calin Chiorean Thu, 09/25/2008 - 06:14
  • Silver, 250 points or more
Hello!
You have a sample configuration. If you are using MPLS and want MPLS MPPP then there are some restrictions (this document will help: http://www.cisco.com/en/US/docs/ios/12_2t/12_2t15/feature/guide/mplsdmlp.html#wp1059434)
You need the config below in both sides RouterA and RouterB
interface Multilink1
ip address XXX.XXX.XXX.XXX 255.255.255.252
no cdp enable
ppp multilink
ppp multilink fragment disable
ppp multilink group 1
interface Serial0/0
bandwidth 2048
no ip address
encapsulation ppp
no cdp enable
ppp multilink
interface Serial0/1
no ip address
encapsulation ppp
no cdp enable
ppp multilink
The utility of MPPP is that it allow to bundle multiple E1/T1 link in one logical interface with and increased bandwidth. For example if you have 2 E1 bundled in 1 MPPP then you have 4Mbps interface (2 x 2Mbps).
Please tell if it is working or need you need more info.
Cheers,
Calin
vinothlb1 Thu, 09/25/2008 - 19:55
Dear Calin,
In my router interface multilink 1
command is not available.. Instead i m having
command like
RouterB(Config)#multilink bundle-name authenticated
is only availabel.
In my ISP side they can be able to configure what sample configuration you provided like above
Calin Chiorean Thu, 09/25/2008 - 22:48
Hello!
What IOS do you have? I wrote version 12.0, but can you put here the full name to see the features?
Thanks!
Cheers,
Calin
vinothlb1 Mon, 10/06/2008 - 03:57
I m having IOS version 12.0(10).. And my router is Cisco 2600.. Whether the router will support
int multilink 1
command. pls explain..
spremkumar Thu, 09/25/2008 - 22:52
  • Red, 2250 points or more
Hi Vinoth
I feel your IOS is not supporting the multilink interface related commands and doesnt support multilink.
Can you try doing an upgrade to the IOS and config the multilink.
you can make use of this link to get your router configured with multilink...
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
regds
