Rob Huffman Fri, 09/26/2008 - 06:00
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Mauricio,
This cable can certainly be used for the Antennas you listed. You may have to design some sort of Mounting apparatus as both of these Antennas are designed to be mounted directly on the 1520. Other than that you should be good to go.
Hope this helps!
Rob
mauramir Fri, 09/26/2008 - 06:48
  • Cisco Employee,
Rob, thanks for your response. I have the following doubt
The Antenna AIR-ANT2480V-N connects directly to the 1520,
this means the antenna has a male N connector and the AP has
a N female connector.
Likewise, the antenna AIR-ANT5180V-N (N-MALE) connects directly to the
1520 (N-Female).
My doubt is thinking about the AIR-ANT5117S-N, this antenna needs
a cable to connect to the 1520, and there are only 2 cable options
This antenna has a N-FEMALE connector so my guess is that these cables
have a N-MALE - N-MALE connector.
AIR-CAB005LL-N
5-ft low loss cable, one straight N connector, one 90-degree N connector
AIR-CAB010LL-N
10-ft low loss cable, one straight N connector, one 90-degree N connector
So I'm still not quite sure this is possible.
Please let me know what you think.
Regards.
Rob Huffman Fri, 09/26/2008 - 08:20
  • Hall of Fame,
    Founding Member
Hi Mauricio,
You are correct :) The first two Antenna models that you referenced would work with that cable. The new one "AIR-ANT5117S-N" would not as these cable are Male to Female.
If you have a look at the "suggested Cables" for the AIR-ANT5117S-N you will see that there are none listed which probably indicates that custom made cable is required (Male to Male).
http://www.cisco.com/en/US/docs/wireless/antenna/installation/guide/ant5117S.html
Hope this helps!
Rob
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
