SNMPv3 config question
Answered Question
Sep 25th, 2008
Hi there,
I'm trying to configure snmpv3 on a 26xx with authpriv but the "priv" option is not available:
swatm(config)#snmp-server group v3group v3 ?
auth group using the authNoPriv Security Level
noauth group using the noAuthNoPriv Security Level
I'm running the following image:
c2600-i-mz.123-26.bin
Is it a question a feature set ?
Correct Answer by Joe Clarke about 8 years 6 months ago
Yes. You need a crypto image (one with k9 in the feature set name) in order to support SNMPv3 authPriv. With IP ONLY, you'll only be able to do authNoPriv.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Thu, 09/25/2008 - 08:47
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
jderrien Thu, 09/25/2008 - 09:13
Makes sense. Thanks a lot for the fast answer !
