Q-in-Q Vlan re-mapping on Metro 6524
Sep 25th, 2008
does anybody experienced problems in vlan remapping on Metro 6524 ?
This is my machine
sh ver
IOS (tm) s6523_rp Software (s6523_rp-ADVIPSERVICESK9-M), Version 12.2(18)ZU2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Tue 30-Jan-07 03:51 by alnguyen
Image text-base: 0x40101040, data-base: 0x42D50000
ROM: System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
BOOTLDR: s6523_rp Software (s6523_rp-ADVIPSERVICESK9-M), Version 12.2(18)ZU2, RELEASE SOFTWARE (fc2)
TSIswec0d uptime is 17 weeks, 6 days, 4 hours, 23 minutes
Time since TSIswec0d switched to active is 17 weeks, 6 days, 4 hours, 21 minutes
System returned to ROM by power-on (SP by power-on)
System image file is "sup-bootflash:s6523-advipservicesk9-mz.122-18.ZU2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco ME-C6524GS-8S (R7000) processor (revision 1.3) with 458752K/65536K bytes of memory.
Processor board ID CAT1209C01F
R7000 CPU at 300Mhz, Implementation 0x27, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
1 Virtual Ethernet/IEEE 802.3 interface
32 Gigabit Ethernet/IEEE 802.3 interfaces
1915K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 256K).
I try to explain my net config.
Basically I've a Huawei provider switch passing me the outer vlan as 726 on g1/31, my Juniper router is config on g1/25 with outer vlan 200 and inner 16 and 20.
Metro Ethernet
interface GigabitEthernet1/25
description towards router
switchport
switchport mode dot1q-tunnel
switchport vlan mapping enable
switchport vlan mapping 200 726
no ip address
no cdp enable
spanning-tree bpdufilter enable
interface GigabitEthernet1/31
description towards PROVIDER
switchport
switchport vlan mapping 726 200
no ip address
no cdp enable
Juniper
> show configuration interfaces ge-7/1/3
flexible-vlan-tagging;
mtu 1518;
unit 16 {
vlan-tags outer 200 inner 16;
family inet {
address 10.10.16.2/30;
unit 20 {
vlan-tags outer 200 inner 20;
family inet {
address 10.10.20.2/30;
Metro Ethernet should remap outer vlan incoming on g1/31 from 723 to 200 and on g1/25 from 200 to 723...
I'm pretty sure the Juniper firewall is config well, I'm not sure the Metro Ethernet is doing what expected.
Pls let me know if you have an idea.
Tks
Ric
william.caban Thu, 09/25/2008 - 09:52
AFAIK, if you specify outer vlan on the Juniper side you should configure the port in the Cisco as a regular 802.1q trunk and allow that particular outer vlan.
On the other side, if you configure the Cisco with the "dot1q-tunnel" statement, you should define "switchport access vlan XXX" with your QinQ "transport" vlan. But in that case, the Juniper should not define an outer vlan (unless you are planning to do some sort of HVPLS).
HTH,
-W
James Lasky Fri, 09/26/2008 - 01:39
as far as I understand you are talking of putting a 3rd outer vlan at the provider interconnection, I'd like to swap the 2nd outer vlan at the interconnection, from 726 to 200..
Tks
Ric
guruprasadr Thu, 10/09/2008 - 00:15
  • Gold, 750 points or more
HI RIC,
Can you please help me with the exact Q-in-Q Configuation on Juniper Routers.
Kindly share if any useful documents available. Thanks in Advance for Help.
Best Regards,
Guru Prasad R
James Lasky Thu, 10/09/2008 - 00:42
Hi Guru
what do you exaclty need ?
In the juniper.net site you can easily find the documentation depending on your junos release.
Greetings,
Riccardo
guruprasadr Thu, 10/09/2008 - 03:56
HI Riccardo,
Thanks for your response.
I am looking for a exact/good documentation on Juniper Routers J - Series.
Also, if you have a good Document on Q-in-Q deployments, please forward the same too.
Guru Prasad R
