Video Advantage doesn't allow IPC to register through Easy VPN Remote
Sep 25th, 2008
I have this environment:
IP Communicator 2.1.3
Video Advantage
CME 4.1 running on Cisco2851 with IOS 12.4(15)T
I have an Easy VPN running between Cisco2851 (Server) and Cisco857 (Remote).
The IPC can register and work normally while Video Advantage is not running.
Once I start VA, the phone unregister and tried about every 50 seconds to register again but unsucessfully.
The same PC running VPN client can connect succesfully with voice and video if I use VPN Client instead of Easy VPN Remote.
I think something in 857 config should be adjusted but I need some tips to identify and troubleshoot the problem.
Thanks in advance
