09-25-2008 10:18 AM - edited 03-03-2019 11:41 PM
I'm tired of adjacency rediscovery because GRE downs/ups an interface to force EIGRP to discover routes again after EIGRP mistankenly accepts a route to a distance tunnel loopback via the tunnel. I want to increase the EIGRP hold timers to greater than that to stop GRE from forcing my network from converging so many times a day. How long does it take for GRE to shut down/up an interface? I will then increase the hold timer to greater than that interval.
Solved! Go to Solution.
09-25-2008 10:36 AM
Why don't you block tunnel destination whic it is learning from tunnel itself? You can use distribute-list or distance commands to stop learning destination routes in EIGRP.
Saju
Pls rate helpful posts
09-25-2008 10:36 AM
Saju
10-09-2011 08:25 PM
How about just not adding the network to EIGRP command?
So if the remote loopback IP is x.x.x.x and local is y.y.y.y
Why not just configure the local EIGRP without "y.y.y.y"?
