NAT, PNAT and policy NAT
Answered Question
Sep 25th, 2008
I have a connection to a 3 party app that has changed. The app is no longer able seperate users coming into the app using nat as seperate connections. I have 4 users that need to use the app at one time. I want to change the nat statement so the users won't pnat on one IP but pick the next available IP in the pool. Since there are only 4 users that will need to go to this site. I am trying not to have a static reserver for them. TAC gave the answer that the pix will pnat anyways if I make the following change. Is there a way without assigning the PC's a static IP?
global (outside) 100 60.100.10.128
crypto ipsec transform-set myset esp-3des esp-md5-hmac
tunnel-group 21.14.41.188 type ipsec-l2l
tunnel-group 21.14.41.188 ipsec-attributes
pre-shared-key *
crypto map newmap 60 match address outside_cryptomap_60
crypto map newmap 60 set peer 21.14.41.188
crypto map newmap 60 set transform-set myset
nat (inside) 100 access-list inside_pnat_outbound_V1
access-list inside_pnat_outbound_V1 extended permit ip 10.0.0.0 255.0.0.0 host 21.14.41.105
access-list inside_pnat_outbound_V1 extended permit ip 10.0.0.0 255.0.0.0 host 21.14.41.106
access-list inside_pnat_outbound_V1 extended permit ip 10.0.0.0 255.0.0.0 host 21.14.41.107
access-list outside_cryptomap_60 extended permit ip host 60.100.10.128 host 21.14.41.105
access-list outside_cryptomap_60 extended permit ip host 60.100.10.128 host 21.14.41.106
access-list outside_cryptomap_60 extended permit ip host 60.100.10.128 host 21.14.41.107
_______________________________________________________________________________________
Idea for change but cisco said it will still PNAT
global (outside) 100 60.100.10.128-60.100.10.135 netmask 255.255.255.248
________________________________________________________________________________________
Correct Answer by drolemc about 8 years 3 months ago
No it works fine, because your ip range is 100 60.100.10.128-60.100.10.135 netmask 255.255.255.248. it contains 8 ip address . You said only 4 users, so first 4 ip allocates that 4 users remaining 4 ip is also available. It works fine.
Overall Rating: 5 (1 ratings)
Correct Answer
drolemc Wed, 10/01/2008 - 08:28
elderr Wed, 10/01/2008 - 10:29
Thanks, I was able to replicate my config in a lab enviroment with older 501s. I was able to determine the it would work. When I brought this up with TAC they told me it would use PNAT and not go to the next IP. Guess you can't always trust TAC. Thanks for verifing it.
