PIX keeps reboot
Sep 25th, 2008
I have a PIX525. It keeps rebooting. I have gone to the monitor and tftp the pix803.bin file back to the flash for few times. Sometimes it will stop at reinitialize flash and then reboot, sometimes it read the image half way, then reboot.
I think the flash is corrupted. Is there any way to format or erase the flash in monitor mode. Or there is any way to stop rebooting?
PCI Device Table.
Bus Dev Func VendID DevID Class Irq
00 00 00 8086 7192 Host Bridge
00 07 00 8086 7110 ISA Bridge
00 07 01 8086 7111 IDE Controller
00 07 02 8086 7112 Serial Bus 9
00 07 03 8086 7113 PCI Bridge
00 0B 00 8086 1001 Ethernet 10
00 0D 00 8086 1209 Ethernet 11
00 0E 00 8086 1209 Ethernet 10
00 11 00 11D4 2F44 Unknown Device 11
00 13 00 8086 1001 Ethernet 5
Cisco Secure PIX Firewall BIOS (4.2) #0: Mon Dec 31 08:34:35 PST 2001
Platform PIX-525
System Flash=E28F128J3 @ 0xfff00000
Use BREAK or ESC to interrupt flash boot.
Use SPACE to begin flash boot immediately.
Reading 102912 bytes of image from flash.
PIX Flash Load Helper
Initializing flashfs...
flashfs[0]: 11 files, 5 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 16128000
flashfs[0]: Bytes used: 15038464
flashfs[0]: Bytes available: 1089536
flashfs[0]: Initialization complete.
Reading image flash:/pix803.bin
Launching image flash:/pix803.bin
256MB RAM
Tak,
I have seen this issue in a PIX 501 and 506. There was no apprent reason for this happening - until I felt the unit which was really hot.
I suggest you check the temperature of the comms room to make sure it's cool enough - other than that raise a support case with your support provider and replace the untit.
That is what I had to do - repladce the firewall.
HTH>
sightlay8 Fri, 09/26/2008 - 06:55
But my secondary PIX is in the same place, so I think it is nor temperature related. I had missed the my own post, it you read my last first post, you will see
under PCI device table. I think one of the Intel fiber NIC is not comparable is the PIX.
But both fiber cards were unplugged from the IBM servers, I don't know why one works, why the other failed. In fact, I tried more fiver cards, most of them causes the PIX reboot.
sightlay8 Fri, 09/26/2008 - 09:22
Since my Pri PIX keeps rebooting, I take it off line. Currently, only the seconday PIX is in the network, it has only failover FO license.
I want to know do I need to fix and put the Pri PIX on line and sync with the Sec PIX in 24 hours. I heard if I don't do that, then the Sec PIX will keeps reboot in every 24 hours. Is this true?
Thx
