Call Manager 4.2(3) Hunt List Configuration Assistance
Sep 25th, 2008
I have programmed a hunt list, line group and hunt pilot. When I dial the hunt pilot number I get a busy signal. I tried resetting the hunt list. Can anyone offer any assistance? Do I need to restart call manager service?
Dianna
Jaime Valencia Thu, 09/25/2008 - 11:51
you shouldn't, try resetting all the elements and try again.
java
if this helps, please rate
Rob Huffman Fri, 09/26/2008 - 05:24
Hi Dianna,
I think Java was referring to doing a reset on the Hunt Pilot, Hunt List and Line Group. You can also ensure that on the Hunt Pilot config page that the "Route this Pattern" checkbox has been checked.
Hope this helps!
Rob
dfhensley Fri, 09/26/2008 - 06:15
Rob,
Thanks for the response.I reset the hunt list and updated the others and continue to get a busy signal when I dial the pilot number. Also route this pattern checkbox was checked. Any other suggestions?
Dianna
Rob Huffman Fri, 09/26/2008 - 08:24
Hi Dianna,
Hmmmmmm...
Did you check the Partition and Calling Search Space?
Rob
