Gatekeeper Call Router Question
Sep 25th, 2008
Lets say I have following:
Gatekeeper A - GK-A
Gatekeeper B - GK-B
Endpoint 1:
Registers with GK-A
E.164: 1000
Endpoint 2:
Registers with GK-A
E.164: 1001
Endpoint 3:
Registers with GK-B
E.164: 1001
Endpoint 4:
Registers with GK-B
E.164: 1002
On GK-A there is a remote zone configured for GK-B. There is a tech prefix set up so that when enpoint 1 or 2 dials 1#.... the call is routed to GK-B.
Here's my problem. Endpoint 1 can call 4 by dialing 1#1002. Works perfectly every time. I want endpoint 1 to be able to call endpoint 3 by dialing 1#1001. That does not work. The call goes to endpoint 2. Is there anyway to get GK-A to respect the 1# and send that call to GK-B?
I've tried several different configurations.
Current configuration is as follows:
zone local GK-A
zone remote GK-B 1719
gw-type-prefix 1#* hopoff GK-B
no shutdown
Anyone have any ideas? I've attached a diagram for clarification of what endpoints are where. Thanks
ivillegas Thu, 10/02/2008 - 11:49
Check the “show gatekeeper endpoint” command in order to make sure that all the endpoints register to the gatekeeper.
Understanding Cisco IOS Gatekeeper Call Routing:
Troubleshooting Gatekeeper Endpoint Call Admission Issues:
tboynton Fri, 10/17/2008 - 06:13
Thanks for the reply.
Yes I do. In this case it does not change the behavior of the call.
