pager line 0 problem
Sep 25th, 2008
i have pix 515E bundle running 6.3(5) version.it is taking "no pager" by default. when i am configuring pager line as 24, it will taking this length but after some time(5-7 mins),again the pager line goes to 0. Simaltaneously when i am trying to do "write memory" sometime it is accepting the command and sometimes not "flash is used by another task". but everything is running fine on standby pix.
suschoud Thu, 09/25/2008 - 12:22
Satya,
Looks like flash has gone bad.Time to replace the good old PIX.
Everything would run fine on standby pix as it has a different hardware.
Sushil
Satya Siba Sund... Thu, 09/25/2008 - 12:46
i found one solution that by enabling ssh ver 2, we can solve the problem.can you please suggest me how can i check the currrent version of ssh in pix(6.3)
suschoud Thu, 09/25/2008 - 12:56
As far as I remember,pix running 6.x will not support version 2.0
It supports version 1.0 and 1.5
Reagrds,
Sushil
Satya Siba Sund... Thu, 09/25/2008 - 13:07
it is taking command to enable ssh ver 2, but i am not sure how to check the current version of ssh
