09-25-2008 12:30 PM - edited 03-09-2019 09:33 PM
I have a DMVPN behind a NAT and when it connects to the hub it's registering its private address.
Routing is working fine to the hub, but when another spoke attempts to contact it, it cannot because all it knows about is the private IP.
Is there any way to register the IKE negotiated address or have NHRP work properly behind a NAT?
hostname BRIVPN02
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.30.2.1 10.30.2.199
ip dhcp pool DHCP
network 10.30.2.0 255.255.255.0
dns-server 172.27.10.31 172.27.10.32 208.200.199.3
default-router 10.30.2.1
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key ABS16855 address 0.0.0.0 0.0.0.0
crypto ipsec transform-set ABS esp-3des esp-md5-hmac
crypto ipsec profile ABS
set security-association lifetime seconds 600
set transform-set ABS
archive
log config
hidekeys
ip ssh version 2
bridge irb
interface Tunnel0
ip address 172.25.254.11 255.255.254.0
no ip redirects
ip mtu 1440
ip nhrp authentication ABS_NET
ip nhrp map multicast dynamic
ip nhrp map multicast 66.54.184.15
ip nhrp map 172.25.254.2 66.54.184.15
ip nhrp network-id 1
ip nhrp nhs 172.25.254.2
ip nhrp shortcut
ip nhrp redirect
no ip split-horizon eigrp 10
tunnel source FastEthernet4
tunnel mode gre multipoint
tunnel key 0
tunnel protection ipsec profile ABS
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface BVI1
ip address 10.30.2.1 255.255.255.0
ip nat inside
router eigrp 10
network 10.30.2.0 0.0.0.255
network 172.25.0.0
no auto-summary
eigrp router-id 172.25.254.11
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map NAT interface FastEthernet4 overload
ip access-list extended NAT
permit ip 10.30.2.0 0.0.0.255 any
route-map NAT permit 10
match ip address NAT
control-plane
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
exec-timeout 60 0
transport input ssh
scheduler max-task-time 5000
end
09-25-2008 02:19 PM
I figured it out, by setting my IPSEC mode to transport it started registering the real IP address but now for some reason my EIGRP is only passing a small portion of routes.
